주요 콘텐츠로 건너뛰기
소개
This guide will describe how to replace a Samsung Galaxy Y's touchscreen and LCD display, should the touchscreen be cracked or the LCD malfunction and cause the phone to display only a black screen.
  1. Use the blue plastic opening tool to pry the back-panel off of the device. Use the blue plastic opening tool to pry the back-panel off of the device. Use the blue plastic opening tool to pry the back-panel off of the device.
    • Use the blue plastic opening tool to pry the back-panel off of the device.
  2. Use the screwdriver with a Phillips #000 screwdriver head to remove the four 5mm screws located in the corner of the interior back panel. Remove the SD card as well by sliding the card out of it's slot. Remove the SD card as well by sliding the card out of it's slot.
    • Use the screwdriver with a Phillips #000 screwdriver head to remove the four 5mm screws located in the corner of the interior back panel.
    • Remove the SD card as well by sliding the card out of it's slot.
  3. 안드로이드 수리 키트
    A new screen or battery is one kit away.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  4. Use the metal pry tool to separate the interior back panel from the interior hardware and screen. Using a metal spudger may cause further damage to your device. Using a metal spudger may cause further damage to your device.
    • Use the metal pry tool to separate the interior back panel from the interior hardware and screen.
    • Using a metal spudger may cause further damage to your device.
  5. Disconnect the orange motherboard connection, then remove the interior hardware from the front screen display. Disconnect the orange motherboard connection, then remove the interior hardware from the front screen display. Disconnect the orange motherboard connection, then remove the interior hardware from the front screen display.
    • Disconnect the orange motherboard connection, then remove the interior hardware from the front screen display.
결론
Aidan Kurz
회원 가입일: 2018년 09월 21일
363 평판
안내서 3개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 147
