주요 콘텐츠로 건너뛰기
Samsung Galaxy Y s5360 Home Button Replacement
필요한 것
  1. Samsung Galaxy Y s5360 Home Button Replacement, Back Panel: 1 단계, 이미지 1/3 Samsung Galaxy Y s5360 Home Button Replacement, Back Panel: 1 단계, 이미지 2/3 Samsung Galaxy Y s5360 Home Button Replacement, Back Panel: 1 단계, 이미지 3/3
    • Use the blue plastic opening tool to pry the back-panel off of the device.
  2. Samsung Galaxy Y s5360 Home Button Replacement, Touch Screen/Display: 2 단계, 이미지 1/3 Samsung Galaxy Y s5360 Home Button Replacement, Touch Screen/Display: 2 단계, 이미지 2/3 Samsung Galaxy Y s5360 Home Button Replacement, Touch Screen/Display: 2 단계, 이미지 3/3
    • Use the screwdriver with a Phillips #000 screwdriver head to remove the four 5mm screws located in the corner of the interior back panel.
    • Remove the SD card as well by sliding the card out of it's slot.
  3. Samsung Galaxy Y s5360 Home Button Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Y s5360 Home Button Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Y s5360 Home Button Replacement: 3 단계, 이미지 3/3
    • Use the metal pry tool to separate the interior back panel from the interior hardware and screen.
    • Using a metal spudger may cause further damage to your device.
  4. Samsung Galaxy Y s5360 Home Button Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Y s5360 Home Button Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Y s5360 Home Button Replacement: 4 단계, 이미지 3/3
    • Disconnect the orange motherboard connection, then remove the interior hardware from the front screen display.
  5. Samsung Galaxy Y s5360 Home Button Replacement, Home Button: 5 단계, 이미지 1/2 Samsung Galaxy Y s5360 Home Button Replacement, Home Button: 5 단계, 이미지 2/2
    • Remove the Home Button from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nico Sawyer
회원 가입일: 09/21/18
103 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 20
전체 시간: 982
