주요 콘텐츠로 건너뛰기
Samsung Gear 2 Speaker Replacement
필요한 것
  1. Samsung Gear 2 Speaker Replacement, Front half and Back half: 1 단계, 이미지 2개 중 1개 Samsung Gear 2 Speaker Replacement, Front half and Back half: 1 단계, 이미지 2개 중 2개
    • Before disassembling your Gear, be sure it is powered off.
    • To remove each strap, locate the metal latches on both sides of the back of the Gear.
    • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
  2. Samsung Gear 2 Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
  3. Samsung Gear 2 Speaker Replacement: 3 단계, 이미지 3개 중 1개 Samsung Gear 2 Speaker Replacement: 3 단계, 이미지 3개 중 2개 Samsung Gear 2 Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
    • Pry the device open from the other side also if it does not fully disassemble from one side.
  4. Samsung Gear 2 Speaker Replacement, Battery: 4 단계, 이미지 2개 중 1개 Samsung Gear 2 Speaker Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Use the pointed side of the spudger to remove the small, orange battery cable.
  5. Samsung Gear 2 Speaker Replacement: 5 단계, 이미지 2개 중 1개 Samsung Gear 2 Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the battery by pulling the white tab on the battery marked "PULL."
    • Make sure the orange battery cable is fully disconnected to avoid ripping it off and tearing it.
  6. Samsung Gear 2 Speaker Replacement, Speaker: 6 단계, 이미지 2개 중 1개 Samsung Gear 2 Speaker Replacement, Speaker: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers, lift the rectangular speaker from the case.
    • Be careful to not pull too quickly and rip the orange connector cable, which is attached to the case with adhesive.
  7. Samsung Gear 2 Speaker Replacement: 7 단계, 이미지 2개 중 1개 Samsung Gear 2 Speaker Replacement: 7 단계, 이미지 2개 중 2개
    • Use tweezers to carefully grab the connector.
    • Gently pull upwards to detach it from the case and from the adhesive.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Devin Mast
회원 가입일: 04/14/14
637 평판
안내서 1개를 작성함
Cal Poly, Team 13-27, Maness Spring 2014 Cal Poly, Team 13-27, Maness Spring 2014 회원
CPSU-MANESS-S14S13G27
4 회원들
안내서 6개를 작성함
3가이드 댓글
what happens if I don't put the speakers back?
alejandrayin5 - 답글
If you don't what the gear to make the sound when using camera or video take the speaker out. It works fine its just a speaker. I did that with my gear 2 that I bought march 2015.
Edna - 답글
Where can I buy the speaker?
Bob Wagenvoort - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 21
전체 시간: 4,295
