주요 콘텐츠로 건너뛰기
Samsung Gear 360 Front Camera Replacement
필요한 것
  1. Samsung Gear 360 Front Camera Replacement, Case: 1 단계, 이미지 1/3 Samsung Gear 360 Front Camera Replacement, Case: 1 단계, 이미지 2/3 Samsung Gear 360 Front Camera Replacement, Case: 1 단계, 이미지 3/3
    • Twist silver ring on the lens counter-clockwise with force to remove it.
  2. Samsung Gear 360 Front Camera Replacement: 2 단계, 이미지 1/2 Samsung Gear 360 Front Camera Replacement: 2 단계, 이미지 2/2
    • Insert a small flathead screwdriver into marked slot on camera lens and pry off camera lens cover.
  3. Samsung Gear 360 Front Camera Replacement: 3 단계, 이미지 1/2 Samsung Gear 360 Front Camera Replacement: 3 단계, 이미지 2/2
    • Using a PH00 screwdriver head, remove all Phillips #00 0.75 mm screws on the front of the camera.
    • Repeat for the back side of the camera.
  4. Samsung Gear 360 Front Camera Replacement: 4 단계, 이미지 1/3 Samsung Gear 360 Front Camera Replacement: 4 단계, 이미지 2/3 Samsung Gear 360 Front Camera Replacement: 4 단계, 이미지 3/3
    • Peel off the black rubber located on the bottom of the device using your hand or a small flathead screwdriver.
  5. Samsung Gear 360 Front Camera Replacement: 5 단계, 이미지 1/2 Samsung Gear 360 Front Camera Replacement: 5 단계, 이미지 2/2
    • Once the black rubber has been removed, unscrew all Phillips #00 0.75 mm screws on the bottom of the device using a PH00 screwdriver head.
  6. Samsung Gear 360 Front Camera Replacement: 6 단계, 이미지 1/2 Samsung Gear 360 Front Camera Replacement: 6 단계, 이미지 2/2
    • Using a plastic opening tool, pry the tripod mount off the device.
  7. Samsung Gear 360 Front Camera Replacement: 7 단계, 이미지 1/2 Samsung Gear 360 Front Camera Replacement: 7 단계, 이미지 2/2
    • Using both hands, carefully remove the right cover off the camera body.
  8. Samsung Gear 360 Front Camera Replacement: 8 단계, 이미지 1/3 Samsung Gear 360 Front Camera Replacement: 8 단계, 이미지 2/3 Samsung Gear 360 Front Camera Replacement: 8 단계, 이미지 3/3
    • To remove the left cover of the camera body, lift the left cover using a small flathead screwdriver and pull it off.
  9. Samsung Gear 360 Front Camera Replacement: 9 단계, 이미지 1/2 Samsung Gear 360 Front Camera Replacement: 9 단계, 이미지 2/2
    • Once the camera body has been removed, lift and pull off the metal support ring using a small flathead screwdriver.
    • Repeat for both sides of the camera.
  10. Samsung Gear 360 Front Camera Replacement: 10 단계, 이미지 1/2 Samsung Gear 360 Front Camera Replacement: 10 단계, 이미지 2/2
    • Remove all Phillips #00 0.75 mm screws from the body of the camera using a PH00 screwdriver head.
  11. Samsung Gear 360 Front Camera Replacement: 11 단계, 이미지 1/3 Samsung Gear 360 Front Camera Replacement: 11 단계, 이미지 2/3 Samsung Gear 360 Front Camera Replacement: 11 단계, 이미지 3/3
    • Carefully lift the three sensors off using a plastic opening tool and pull them aside.
  12. Samsung Gear 360 Front Camera Replacement: 12 단계, 이미지 1/2 Samsung Gear 360 Front Camera Replacement: 12 단계, 이미지 2/2
    • Carefully use a plastic opening tool to separate the gray case from the black case on the device.
  13. Samsung Gear 360 Front Camera Replacement: 13 단계, 이미지 1/3 Samsung Gear 360 Front Camera Replacement: 13 단계, 이미지 2/3 Samsung Gear 360 Front Camera Replacement: 13 단계, 이미지 3/3
    • Insert a plastic removal tool underneath the four sensors on the motherboard to fully separate the camera case.
  14. Samsung Gear 360 Front Camera Replacement, Speaker: 14 단계, 이미지 1/3 Samsung Gear 360 Front Camera Replacement, Speaker: 14 단계, 이미지 2/3 Samsung Gear 360 Front Camera Replacement, Speaker: 14 단계, 이미지 3/3
    • Within gold metal half of the case, unscrew the Phillips #00 0.75 mm screw located on the metal plate using a PH00 screwdriver.
    • Using a plastic opening tool, remove the metal cover.
  15. Samsung Gear 360 Front Camera Replacement: 15 단계, 이미지 1/3 Samsung Gear 360 Front Camera Replacement: 15 단계, 이미지 2/3 Samsung Gear 360 Front Camera Replacement: 15 단계, 이미지 3/3
    • Using a PH000 screwdriver head, unscrew all Phillips #00 0.75 mm screws.
    • To remove the speaker from the device, use a plastic opening tool on the edge and gently lift it up.
  16. Samsung Gear 360 Front Camera Replacement, Front Camera: 16 단계, 이미지 1/3 Samsung Gear 360 Front Camera Replacement, Front Camera: 16 단계, 이미지 2/3 Samsung Gear 360 Front Camera Replacement, Front Camera: 16 단계, 이미지 3/3
    • Using a PH000 screwdriver head, unscrew both screws on the remaining case.
    • Use a plastic opening tool to lift the front camera module from the case.
결론
Connor
회원 가입일: 02/20/17
454 평판
안내서 3개 작성하였습니다
USF Tampa, Team S3-G5, Sullivan Spring 2017 USF Tampa, Team S3-G5, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S3G5
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 851
