소개
This guide will show you how to remove the rear camera module from the Samsung Gear 360. Like the front camera, this module can be removed by completing a tear-down of the device, and unscrewing the module from there.
필요한 것
Within the grey half of the case, unscrew both Phillips #00 0.75 mm screws located on the metal plate using PH00 screwdriver.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
