주요 콘텐츠로 건너뛰기
Samsung Gear Live Back Replacement
필요한 것
  1. Samsung Gear Live Back Replacement, Lay the watch face-down: 1 단계, 이미지 1/1
    • Lay the watch face-down on a flat, stable surface.
  2. Samsung Gear Live Back Replacement, Remove the holding pin: 2 단계, 이미지 1/1
    • Press the watchband down against the work surface.
    • Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
  3. Samsung Gear Live Back Replacement, Remove the watchband: 3 단계, 이미지 1/1
    • With the spring-loaded pin pressed in, the watch band should release easily.
    • Gently pull the band away from the body of the watch.
    • Repeat steps 2 and 3 for the opposite side.
  4. Samsung Gear Live Back Replacement, Locate the four screws: 4 단계, 이미지 1/1
    • With the watch laying face-down, locate the four screws. They are located on the back of the watch, at the four corners.
  5. Samsung Gear Live Back Replacement, Remove the 4 screws: 5 단계, 이미지 1/1
    • Using a Torx-T5 screwdriver, remove each of the four 4mm screws and set them aside.
  6. Samsung Gear Live Back Replacement, Pry off the back of the watch.: 6 단계, 이미지 1/1
    • Gently work the plastic opening tool under the top edge of the watch’s back cover.
  7. Samsung Gear Live Back Replacement, Lift off the back cover: 7 단계, 이미지 1/2 Samsung Gear Live Back Replacement, Lift off the back cover: 7 단계, 이미지 2/2
    • With the watch’s back cover pried loose, gently lift it away from the front half of the watch.
  8. Samsung Gear Live Back Replacement, Set both halves of the watch aside: 8 단계, 이미지 1/1
    • Lay both halves of the watch body assembly face down (with internal components facing up).
결론
Keith Cooper
회원 가입일: 09/25/14
1,241 평판
안내서 6개 작성하였습니다
USF Tampa, Team 1-7, Brown Fall 2014 USF Tampa, Team 1-7, Brown Fall 2014 회원
USFT-BROWN-F14S1G7
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Mention the screwdriver in the tools needed section.
Dan Brown - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 9
전체 시간: 1,730
