주요 콘텐츠로 건너뛰기
Samsung Gear S Display Assembly Replacement
필요한 것
  1. Samsung Gear S Display Assembly Replacement, Display Assembly: 1 단계, 이미지 1/3 Samsung Gear S Display Assembly Replacement, Display Assembly: 1 단계, 이미지 2/3 Samsung Gear S Display Assembly Replacement, Display Assembly: 1 단계, 이미지 3/3
    • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
  2. Samsung Gear S Display Assembly Replacement: 2 단계, 이미지 1/2 Samsung Gear S Display Assembly Replacement: 2 단계, 이미지 2/2
    • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
    • Some force is needed due to adhesive seal.
  3. Samsung Gear S Display Assembly Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
  4. Samsung Gear S Display Assembly Replacement: 4 단계, 이미지 1/1
    • Locate the ribbon assembly attaching the display to the motherboard.
  5. Samsung Gear S Display Assembly Replacement: 5 단계, 이미지 1/1
    • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
  6. Samsung Gear S Display Assembly Replacement: 6 단계, 이미지 1/1
    • Now the watch should be in three separate pieces.
결론
To reassemble your device, follow these instructions in reverse order. You will need an adhesive to connect the screen back to the rest of the watch.
다른 19명이 해당 안내서를 완성하였습니다.
Crystal Schmitt
회원 가입일: 09/03/15
679 평판
안내서 1개 작성함
USF Tampa, Team 12-1, Blackwell Fall 2015 USF Tampa, Team 12-1, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G1
4 회원들
안내서 5개 작성하였습니다
댓글 16개
Where can i get the LCD for Gear S
Kuek See Chuan - 답글
my screen flashing light and show on screen lines
avi mor - 답글
Hi my gear is showing the watch face setting then glitches to the photo setting and is not allowing me to use any other apps?
Mark Measures - 답글
My watch is doing the same thing. Did you get a fix for it?
steve Walks -
There are flashing yellow lights on the screen, could I fix that?
Alex - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 15,507
