주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Gear S Home Button Assembly Replacement
필요한 것
    1. Samsung Gear S Home Button Assembly Replacement, Display Assembly: 1 단계, 이미지 3개 중 1개 Samsung Gear S Home Button Assembly Replacement, Display Assembly: 1 단계, 이미지 3개 중 2개 Samsung Gear S Home Button Assembly Replacement, Display Assembly: 1 단계, 이미지 3개 중 3개
      • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
      댓글 쓰기
    2. Samsung Gear S Home Button Assembly Replacement: 2 단계, 이미지 2개 중 1개 Samsung Gear S Home Button Assembly Replacement: 2 단계, 이미지 2개 중 2개
      • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
      • Some force is needed due to adhesive seal.
      댓글 쓰기
    3. Samsung Gear S Home Button Assembly Replacement: 3 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
      댓글 쓰기
    4. Samsung Gear S Home Button Assembly Replacement: 4 단계, 이미지 1개 중 1개
      • Locate the ribbon assembly attaching the display to the motherboard.
      댓글 쓰기
    5. Samsung Gear S Home Button Assembly Replacement: 5 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
      댓글 쓰기
    6. Samsung Gear S Home Button Assembly Replacement: 6 단계, 이미지 1개 중 1개
      • Now the watch should be in three separate pieces.
      댓글 쓰기
    1. Samsung Gear S Home Button Assembly Replacement, Home Button Assembly: 7 단계, 이미지 2개 중 1개 Samsung Gear S Home Button Assembly Replacement, Home Button Assembly: 7 단계, 이미지 2개 중 2개
      • Locate the home ribbon connector attached to the wrist side (side that faces the user when wearing it) of the motherboard assembly.
      • Locate the home ribbon assembly attached to the screen side of the motherboard assembly.
      댓글 쓰기
    2. Samsung Gear S Home Button Assembly Replacement: 8 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to gently pry up on the home ribbon connector.
      댓글 쓰기
    3. Samsung Gear S Home Button Assembly Replacement: 9 단계, 이미지 1개 중 1개
      • Use the spudger to pry up the home ribbon assembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Luis Franco
회원 가입일: 09/03/15
1,076 평판
안내서 4개를 작성함
USF Tampa, Team 12-1, Blackwell Fall 2015 USF Tampa, Team 12-1, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G1
4 회원들
안내서 5개를 작성함
2가이드 댓글
where can i buy the home buton?
Hanna Iskandar - 답글 공유
I am in search of the SM-R750v Housing Back Cover, any suggestions
Rita Arnold - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 33
전체 시간: 5,656
