소개
This guide will give step by step instructions showing how to repair the microphone on the Samsung Gear S.
필요한 것
Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
is it a good idea to apply some heat first?
Do we need to apply some heat?
I found the use of a razor blade was very helpful. Very thin and I was able to lift the edge.
I would assume a small amount of heat would do wonders here...
DO NOT USE A RAZOR BLADE! It instantly shattered my screen, right from the start!
It is double sided tape, around the entire perimeter, and across the middle, upside down U fashion.
You can see the glue remnants in Step 3’s photo. Heat it first, even with a blow dryer, as I did not.
It *may* work with an Exacto blade, but not a regular razor blade, given my broken display.
On top of that, the corner shown in the photo is not the corner you want a blade near, as it cut my wiring to the display!
Use the top left corner, away from the cabling.
The notes don’t tell you that you need to have an adhesive to reconnect the display, until the very end.
But hey, they’ll sell you more parts if you don’t follow my advice.
You must have put the razor blade to far in because I used a single blade/ not the double side blade and it worked great and used the same adhesive by heating it up with a hair dryer.
Apply heat dont attempt to do this with out heat
Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
The metal rim has to bend away from the motherboard in order for this to come out. Use a guitar pick.
Now the watch should be in three separate pieces.
Where does that piece to the left coming from?
Locate the microphone on the lower right corner of the plastic motherboard assembly .
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
any chance of posting were to buy a new mic please..
