주요 콘텐츠로 건너뛰기
Samsung Gear S Speaker Replacement
필요한 것
  1. Samsung Gear S Speaker Replacement, Display Assembly: 1 단계, 이미지 1/3 Samsung Gear S Speaker Replacement, Display Assembly: 1 단계, 이미지 2/3 Samsung Gear S Speaker Replacement, Display Assembly: 1 단계, 이미지 3/3
    • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
  2. Samsung Gear S Speaker Replacement: 2 단계, 이미지 1/2 Samsung Gear S Speaker Replacement: 2 단계, 이미지 2/2
    • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
    • Some force is needed due to adhesive seal.
  3. Samsung Gear S Speaker Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
  4. Samsung Gear S Speaker Replacement: 4 단계, 이미지 1/1
    • Locate the ribbon assembly attaching the display to the motherboard.
  5. Samsung Gear S Speaker Replacement: 5 단계, 이미지 1/1
    • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
  6. Samsung Gear S Speaker Replacement: 6 단계, 이미지 1/1
    • Now the watch should be in three separate pieces.
  7. Samsung Gear S Speaker Replacement, Speaker: 7 단계, 이미지 1/1
    • Locate the speaker in the upper left corner of the housing.
    • Locate the speaker ribbon connector directly below the speaker.
  8. Samsung Gear S Speaker Replacement: 8 단계, 이미지 1/1
    • Use the plastic opening tool to gently pry upwards on the speaker's ribbon connector.
  9. Samsung Gear S Speaker Replacement: 9 단계, 이미지 1/1
    • Use the spudger to gently pry upwards on the speaker housing.
    • Note: The speaker housing is attached with adhesive, therefore, some force is required.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Luis Franco
회원 가입일: 09/03/15
1,076 평판
안내서 4개 작성하였습니다
USF Tampa, Team 12-1, Blackwell Fall 2015 USF Tampa, Team 12-1, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G1
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Do you have a place where we can buy the speaker part?
christopher borget - 답글
Ya. Looking for speaker part myself... Where we find it at?
Tony Tone - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 8
30일 전: 9
전체 시간: 3,277
