주요 콘텐츠로 건너뛰기
Samsung Gear S2 Battery Replacement
필요한 것
  1. Samsung Gear S2 Battery Replacement, Watch Strap: 1 단계, 이미지 1/2 Samsung Gear S2 Battery Replacement, Watch Strap: 1 단계, 이미지 2/2
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
  2. Samsung Gear S2 Battery Replacement: 2 단계, 이미지 1/2 Samsung Gear S2 Battery Replacement: 2 단계, 이미지 2/2
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
  3. Samsung Gear S2 Battery Replacement: 3 단계, 이미지 1/2 Samsung Gear S2 Battery Replacement: 3 단계, 이미지 2/2
    • Repeat the procedure from step 2 for the other strap.
  4. Samsung Gear S2 Battery Replacement, Back: 4 단계, 이미지 1/2 Samsung Gear S2 Battery Replacement, Back: 4 단계, 이미지 2/2
    • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
    • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
  5. Samsung Gear S2 Battery Replacement, Motherboard: 5 단계, 이미지 1/2 Samsung Gear S2 Battery Replacement, Motherboard: 5 단계, 이미지 2/2
    • Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
  6. Samsung Gear S2 Battery Replacement: 6 단계, 이미지 1/3 Samsung Gear S2 Battery Replacement: 6 단계, 이미지 2/3 Samsung Gear S2 Battery Replacement: 6 단계, 이미지 3/3
    • Using a spudger, pry up the three cables.
  7. Samsung Gear S2 Battery Replacement: 7 단계, 이미지 1/2 Samsung Gear S2 Battery Replacement: 7 단계, 이미지 2/2
    • Using the flat end of a spudger, pry up the motherboard.
    • Make sure the cable is fed through the hole to avoid damaging it.
    • The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
  8. Samsung Gear S2 Battery Replacement, Battery: 8 단계, 이미지 1/2 Samsung Gear S2 Battery Replacement, Battery: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, lift the battery casing.
    • Make sure the cables are fed through their gaps to avoid damaging them.
  9. Samsung Gear S2 Battery Replacement: 9 단계, 이미지 1/2 Samsung Gear S2 Battery Replacement: 9 단계, 이미지 2/2
    • Flip the battery casing over and using a spudger, push on the battery to free it from the casing.
    • Once the battery is free, use the flat end of a spudger to lift up the battery cable.
결론
다른 100명이 해당 안내서를 완성하였습니다.
Jacob Baldwin
회원 가입일: 02/20/17
3,412 평판
안내서 5개 작성하였습니다
USF Tampa, Team S2-G3, Sullivan Spring 2017 USF Tampa, Team S2-G3, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S2G3
3 회원들
안내서 23개 작성하였습니다
댓글 39개
Excellent guidelines, and do you have steps for s3 frontier
pedro tiburcio - 답글
A reference to the battery part number would be great.
Harold Turner - 답글
Very good job and very easy
JEAN PIERRE - 답글
I have the Gear S2 3G version R730V and purchased a battery thinking these instructions would work, but once I opened the watch it is not the same as the one above. Does anyone have instructions on how to replace the batter on the R730V??
Irene - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 75
30일 전: 359
전체 시간: 154,422
