이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the watch over so that the face is down.
Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
Using your finger, push forward on the release while pulling up on the strap.
Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
Using the flat end of a spudger, pry up the motherboard.
The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
Flip the battery casing over and using a spudger, push on the battery to free it from the casing.
Once the battery is free, use the flat end of a spudger to lift up the battery cable.
다른 100명이 해당 안내서를 완성하였습니다.
댓글 39개
Excellent guidelines, and do you have steps for s3 frontier
A reference to the battery part number would be great.
Very good job and very easy
eb-br720ABE
