소개
This is just a look into the Samsung gear S2.
필요한 것
You will need a Y 00 screwdriver, a PH 0 screwdriver, a spudger, and some tweezers.
Pry between the bottom and top portions of the watch with a spudger in the area marked. Be sure not to insert the spudger more than about 3 mm so as not to damage the internals of the watch.
Also, there is a seal inside the watch that goes along the perimeter inside the bottom of the casing. Be sure not to damage this, otherwise you lose water resistance.
What’s the name of that coil assembly that is located with inside the watch that wirelessly charges it’s battery?
Please add how hard you should press into the watch, I've used 4 different tools now and this case refuses to open.
다른 26명이 해당 안내서를 완성하였습니다.
댓글 26개
Thank you for a picture of the internals. I'm thinking about "restoring" a Gear S2 classic.
Tom Bowden - 답글
How do I replace the screen? It seems like it’s glued on.
Hi Austin, tks for making the guide, How to remove the rotating bezel?
Is the WiFi-only variant or is it cell capable? Wondering if I can swap the board from an AT&T or GSM unlocked S2 Classic into a gold S2 Classic frame cause Samsung doesn't sell cellular models of the gold S2 Classic.
Just S2 Classic wifi. I am unsure of any similarities or differences in the S2 cellular vs S2 classic. However, in my experience with phones and music players, the device with cellular capabilities needs to have an additional antenna or two to grab those signals. It is most likely that what you are trying to do will not work.
Austin -
Hi, I got a Y00 screwdriver to try this, but the point is far too small. Am I missing something?
eandekelly - 답글
Not all bits/ screwdrivers are made to the exact dimensions as another. So my Y00 may be bigger in size than yours. Maybe try a Y0 from the place you ordered, or just buy the 64 bit toolkit. That is what I used in this guide.
Austin -
thanks for the quick response, I'll give the toolkit a try
eandekelly - 답글
Got the toolkit and the Y00 there fitted perfectly.
Replaced the battery and the watch worked because the new battery had a 25% charge.
Unfortunately it still won't charge :(
eandekelly - 답글
Since the battery had a 25% charge, I did a hardware reset and tried again. Now it will charge to 65% - many thanks for the instructions
eandekelly - 답글
You are welcome.
Austin -
This is an excellent disassembly. Where can I buy the back cover parts for the S2 classic Rose Gold? It is model SM-R732.
rayramirez - 답글
The bezel can be pried off carefully as it’s held on with a plastic ring on the inside but be careful as beneath the bezel are 4 tiny bearings mounted on 4 tiny springs
Any thoughts on removing / replacing the glass on the back plate? Just the glass circle… can it easily be removed? Is the replacement glass pre-glued? Do you need a special glue (or is superglue enough)? Do you have to remove the back plate to remove the glass? I shattered the glass, so it’s probably going to come off in splinters… and I bought a Y-driver set, so I’m prepared to remove the back plate if needed… Thanks
Any parts that you need can be obtained from samsungparts.com (authorized original parts distributor). It is a little difficult to navigate the site, but just use common sense and you should be fine. This is the link to the battery. Model SM-R732. I would use a silicone type glue to secure the glass as that would be water resistant. Do please remove the back to replace the glass, as it is fairly simple to do and you don’t want glass shards loose in your watch.
Short of the exercise of taking the S2 apart, is there any planned benefit, like replacing the battery? If so, from where can a battery be obtained?? ronkriel@earthlink.net. BTW, I have your (IFIXIT) 128 bit Universal Bit Kit, and the smallest “Y” bit is a zero. It is too big. TTFN, Ron
I was not using the 128 bit universal kit from Ifixit, I was using the 64 bit kit from Ifixit. You can always check the description of the kit to see what bits it includes before ordering.
Do you know where to buy the waterproof seal mine came unglued
So this model doesn’t have a sim card?
Anyone know where I can purchase that flat woven copper wire that is located at the bottom section of my Samsung Gear 2S watch? I need to replace mine.
what the Y screwdriver no 0.6 or 1.5
