주요 콘텐츠로 건너뛰기
Samsung Gear S2 Motherboard Replacement
필요한 것
  1. Samsung Gear S2 Motherboard Replacement, Watch Strap: 1 단계, 이미지 1/2 Samsung Gear S2 Motherboard Replacement, Watch Strap: 1 단계, 이미지 2/2
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
  2. Samsung Gear S2 Motherboard Replacement: 2 단계, 이미지 1/2 Samsung Gear S2 Motherboard Replacement: 2 단계, 이미지 2/2
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
  3. Samsung Gear S2 Motherboard Replacement: 3 단계, 이미지 1/2 Samsung Gear S2 Motherboard Replacement: 3 단계, 이미지 2/2
    • Repeat the procedure from step 2 for the other strap.
  4. Samsung Gear S2 Motherboard Replacement, Back: 4 단계, 이미지 1/2 Samsung Gear S2 Motherboard Replacement, Back: 4 단계, 이미지 2/2
    • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
    • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
  5. Samsung Gear S2 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/2 Samsung Gear S2 Motherboard Replacement, Motherboard: 5 단계, 이미지 2/2
    • Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
  6. Samsung Gear S2 Motherboard Replacement: 6 단계, 이미지 1/3 Samsung Gear S2 Motherboard Replacement: 6 단계, 이미지 2/3 Samsung Gear S2 Motherboard Replacement: 6 단계, 이미지 3/3
    • Using a spudger, pry up the three cables.
  7. Samsung Gear S2 Motherboard Replacement: 7 단계, 이미지 1/2 Samsung Gear S2 Motherboard Replacement: 7 단계, 이미지 2/2
    • Using the flat end of a spudger, pry up the motherboard.
    • Make sure the cable is fed through the hole to avoid damaging it.
    • The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Jacob Baldwin
회원 가입일: 02/20/17
3,412 평판
안내서 5개 작성하였습니다
USF Tampa, Team S2-G3, Sullivan Spring 2017 USF Tampa, Team S2-G3, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S2G3
3 회원들
안내서 23개 작성하였습니다
댓글 6개
Where do you get the mother board.
Walter Meekins - 답글
I'm looking for a new motherboard as well.
Karen -
Where do you buy a motherboard???
kiki3w - 답글
Do you have a good source for motherboards? Hope it helps that I +30’d you!
darkfeather72 - 답글
Ok motherboard replaced but how can I have the watch to work in normal mode and not in factory release.?
Cyan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 36
전체 시간: 16,798
