주요 콘텐츠로 건너뛰기
Samsung Gear S2 Motherboard Replacement
필요한 것
  1. Samsung Gear S2 Motherboard Replacement, Watch Strap: 1 단계, 이미지 2개 중 1개 Samsung Gear S2 Motherboard Replacement, Watch Strap: 1 단계, 이미지 2개 중 2개
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
  2. Samsung Gear S2 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Samsung Gear S2 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
  3. Samsung Gear S2 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Samsung Gear S2 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Repeat the procedure from step 2 for the other strap.
  4. Samsung Gear S2 Motherboard Replacement, Back: 4 단계, 이미지 2개 중 1개 Samsung Gear S2 Motherboard Replacement, Back: 4 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
    • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
  5. Samsung Gear S2 Motherboard Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 Samsung Gear S2 Motherboard Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
  6. Samsung Gear S2 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Samsung Gear S2 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Samsung Gear S2 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Using a spudger, pry up the three cables.
  7. Samsung Gear S2 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Samsung Gear S2 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Using the flat end of a spudger, pry up the motherboard.
    • Make sure the cable is fed through the hole to avoid damaging it.
    • The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jacob Baldwin
회원 가입일: 02/20/17
3,420 평판
안내서 5개를 작성함
USF Tampa, Team S2-G3, Sullivan Spring 2017 USF Tampa, Team S2-G3, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S2G3
3 회원들
안내서 23개를 작성함
댓글 6개
Where do you get the mother board.
Walter Meekins - 답글
I'm looking for a new motherboard as well.
Karen -
Where do you buy a motherboard???
kiki3w - 답글
Do you have a good source for motherboards? Hope it helps that I +30’d you!
darkfeather72 - 답글
Ok motherboard replaced but how can I have the watch to work in normal mode and not in factory release.?
Cyan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 17,005
