주요 콘텐츠로 건너뛰기
소개
Has the buckle on the strap of your watch become broken, or do you just want to replace the factory strap with a custom one? Just swap it out.
부품
지정된 부품이 없습니다.
  1. Flip the watch over so that the face is down. Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
    The warning to turn off the watch to avoid electrical shock was a joke, right?!
    nanev - 답글
    The screws don't seem to be turning easily. What's the best way to loosen them without stripping them?
    Mark Franz - 답글
    I’m going to be shocked by a dead 3.8V battery? Of course, only if the watch is powered on. Ridiculous statements like this do not reflect positively on the credibility of this entire procedure. If the author seriously thinks this is a danger then I question your basic understanding of electronics.
    Alex Tatistcheff - 답글
    … to avoid being shocked when you lose your data! :)
    Reuben Janzen-Martin - 답글
  2. Using your finger, push forward on the release while pulling up on the strap. You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
    The bracelet should be removed first!
    Das Armband sollte zuerst entfernt werden!
    Wilhelm Gregorius - 답글
  3. Repeat the procedure from step 2 for the other strap. Repeat the procedure from step 2 for the other strap.
    • Repeat the procedure from step 2 for the other strap.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Jacob Baldwin
회원 가입일: 2017년 02월 20일
3,291 평판
안내서 5개 작성하였습니다
USF Tampa, Team S2-G3, Sullivan Spring 2017 USF Tampa, Team S2-G3, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S2G3
3 회원들
안내서 19개 작성하였습니다
댓글 6개
can you also provide instruction to change home button on Gear S2
thanks
inder kapoor - 답글
you have to buy the continuing transfunctioner to change the home button on the gear s2
i have some for sale if interested
bobby - 답글
Where can you buy new straps?
Olga Andreu - 답글
YOU DO NOT NEED TO REMOVE THE SCREWS. Step 1 is completely irrelevant.
Ryo Kimball - 답글
How can I take the metal piece that was broken off from the strap, that's stuck to the watch
Vang Lesh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 71
전체 시간: 6,834
