이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Has the buckle on the strap of your watch become broken, or do you just want to replace the factory strap with a custom one? Just swap it out.
필요한 것
Flip the watch over so that the face is down.
Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 6개
can you also provide instruction to change home button on Gear S2
thanks
Where can you buy new straps?
Ebay Amazon etc.
YOU DO NOT NEED TO REMOVE THE SCREWS. Step 1 is completely irrelevant.
