주요 콘텐츠로 건너뛰기
Samsung Gear S3 Frontier Back Cover Replacement
필요한 것
  1. Samsung Gear S3 Frontier Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Place the watch screen-down so that its back cover is showing.
  2. Samsung Gear S3 Frontier Back Cover Replacement: 2 단계, 이미지 1/2 Samsung Gear S3 Frontier Back Cover Replacement: 2 단계, 이미지 2/2
    • Remove the four 4.2mm screws with a Y00 screwdriver.
  3. Samsung Gear S3 Frontier Back Cover Replacement: 3 단계, 이미지 1/3 Samsung Gear S3 Frontier Back Cover Replacement: 3 단계, 이미지 2/3 Samsung Gear S3 Frontier Back Cover Replacement: 3 단계, 이미지 3/3
    • This step will ruin the water-proof seal.
    • Wedge the metal spudger in between the back cover and the frame along the seam.
    • Use force to pry the back cover away from the main watch frame.
    • This step requires a lot of force. You can use a Jimmy in place of a metal spudger to make the process easier.
결론
다른 17명이 해당 안내서를 완성하였습니다.
William Hurty
회원 가입일: 10/08/18
2,716 평판
안내서 3개 작성하였습니다
Cal Poly, Team S15-G2, White Fall 2018 Cal Poly, Team S15-G2, White Fall 2018 회원
CPSU-WHITE-F18S15G2
4 회원들
안내서 34개 작성하였습니다
댓글 10개
How do I ensure the watch will be waterproof again?
Robert Simpson - 답글
Doesn’t sound like anything a careful application of RTV can’t handle. It can be found in small squeeze tubes at most auto parts stores, where it might be sold as ‘liquid gasket’ or something similar. You can also get it at hardware stores in large tubes meant to be used in caulking guns.
If the original gasket still looks good, no cracks or breaks in it after you remove the cover, I’d wager it will still be water proof after you put it back on. If it’s damaged, I would try to remove it entirely, and likewise, if the replacement cover doesn’t have a seal, you would want to apply some RTV or similar sealant. Ideally, I would use a syringe for this. In the US at least, you can buy needles at a pharmacy without a prescription, you just have to ask for them at the pharmacy counter. Suck some RTV into the syringe, and apply it carefully on the sealing surfaces of the cover. Put the cover on before the RTV dries so it mates to the surfaces, give it about an hour to cure, and it should be water proof.
Jonathan Sherrill -
Will the watch be waterproof again once the new back is installed!??
Paul O'Regan - 답글
The back case of the watch contains an integrated rubberised o-ring.
Force is best applied by taking the band off and working at the edges adjacent to where the band meets the case.
There are small lips here where the thin metal Jimmy can be used to pry the case off with patience and low force by alternating between each end of the case.
The metal spudger tool recommded by this guide is the wrong tool for the job. The ends are far too thick.
Jimmy used: Jimmy
Ben Russell - 답글
I lost 1 screw for the back cover. Where can I get a replacement? I measured the screw. Body Ø.045” x Length .133” x Head Ø.072. Metric conversion probably screw size M1.2 x 3.5mm lg. Any help would be greatly appreciated. Thanks
Bailey Major - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 59
30일 전: 198
전체 시간: 27,735
