소개
Is your bezel ring scuffed up, unresponsive, or not as satisfyingly clicky as it was new? This guide shows you how to remove and replace the front bezel ring.
필요한 것
Hold the watch firmly in one hand, face up.
Place the iFixit Opening Tool under the bezel ring and use prying motion to remove.
다른 26명이 해당 안내서를 완성하였습니다.
댓글 42개
I’ve tried lining it up with the screen and pushing it in about 50 times now and everytime I do it clicks, but after rotating it a few times the bezel locks and I can’t rotate it anymore. YES all the ball bearings are in the right place, YES the springs are in the right place. There’s this little plastic piece that I can’t tell if it goes inside the bezel piece or if it goes on top of the watch next to the ball bearings. I’m able to get the bezel back on when I put the little plastic piece on the bezel, it clicks right in, but it locks up. When I leave the little plastic piece on the watch I can’t get it to click in at all. I think I just royally f’ed up my watch!
did u manage to fix it?
Dave Green - 답글
Interested to know if anyone had much success with this process.
