주요 콘텐츠로 건너뛰기
Samsung Gear S3 Frontier Bezel Ring Replacement
필요한 것
  1. Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: 1 단계, 이미지 1/3 Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: 1 단계, 이미지 2/3 Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: 1 단계, 이미지 3/3
    • Contains small springs and ball bearings. We suggest working over a plate or tray.
    • Hold the watch firmly in one hand, face up.
    • Place the iFixit Opening Tool under the bezel ring and use prying motion to remove.
    • The plastic retainer is manufactured with an open gap, you did not break it.
    • For reassembly, set the plastic retainer in the ring, then press the ring down until it snaps in place.
결론
다른 26명이 해당 안내서를 완성하였습니다.
Mark Iknoian
회원 가입일: 10/08/18
1,033 평판
안내서 1개 작성함
Cal Poly, Team S15-G2, White Fall 2018 Cal Poly, Team S15-G2, White Fall 2018 회원
CPSU-WHITE-F18S15G2
4 회원들
안내서 34개 작성하였습니다
댓글 42개
I got the bezel popped off to clean it. Now it wont pop back on! Help!
shileski - 답글
line up the bezel with the screen and push it in
Arthur -
I’ve tried lining it up with the screen and pushing it in about 50 times now and everytime I do it clicks, but after rotating it a few times the bezel locks and I can’t rotate it anymore. YES all the ball bearings are in the right place, YES the springs are in the right place. There’s this little plastic piece that I can’t tell if it goes inside the bezel piece or if it goes on top of the watch next to the ball bearings. I’m able to get the bezel back on when I put the little plastic piece on the bezel, it clicks right in, but it locks up. When I leave the little plastic piece on the watch I can’t get it to click in at all. I think I just royally f’ed up my watch!
Hardy T - 답글
did u manage to fix it?
Dave Green - 답글
Interested to know if anyone had much success with this process.
Seth Armour - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 83
30일 전: 387
전체 시간: 86,947
