주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Is your device completely unresponsive? Did all of the other troubleshooting and replacement guides not fix your problem? If so, there's a good chance your motherboard needs to be replaced. Follow this guide.
  1. Place the watch screen-down so that its back cover is showing.
    • Place the watch screen-down so that its back cover is showing.
  2. Remove the four 4.2mm screws with a Y00 screwdriver. Remove the four 4.2mm screws with a Y00 screwdriver.
    • Remove the four 4.2mm screws with a Y00 screwdriver.
  3. Wedge the metal spudger in between the back cover and the frame along the seam. Use force to pry the back cover away from the main watch frame. This step requires a lot of force. You can use a Jimmy in place of a metal spudger to make the process easier.
    • Wedge the metal spudger in between the back cover and the frame along the seam.
    • Use force to pry the back cover away from the main watch frame.
    • This step requires a lot of force. You can use a Jimmy in place of a metal spudger to make the process easier.
    • This step will ruin the water-proof seal.
  4. Detach the three connectors on the motherboard using your fingernail. The connectors are easy to pop off. Minimal force is necessary. The connectors are easy to pop off. Minimal force is necessary.
    • Detach the three connectors on the motherboard using your fingernail.
    • The connectors are easy to pop off. Minimal force is necessary.
  5. Separate the motherboard and front screen assembly using a spudger. Separate the motherboard and front screen assembly using a spudger. Separate the motherboard and front screen assembly using a spudger.
    • Separate the motherboard and front screen assembly using a spudger.
    Oui tuto bien clair. Opération réussi !
    Bien qu’adroit de mes mains, et après avoir découvert la “bête à coeur ouvert”, je ne sais pas si je me serais lancé... C’est tout l’interêt de ce Tuto qui invite à le faire (car pas trop de détails), et qui suivit pas à pas permet de s’en sortir. Bravo
    Merci Dan.S
    Dan.S - 답글
    Ustedes reparan el gear s3 Frontier? El mío presenta una falla, algunas veces se ve la pantalla, otras veces solo muestra un error y se pone oscura, no sé si sea la placa o la pantalla la que de el error. Gracias
    Daniel Albornoz - 답글
    Better replace the 2 bolts from next step first.
    Gabriel Pinho - 답글
  6. Using a JIS #00 screwdriver, remove the two 4.5 mm screws. Using a JIS #00 screwdriver, remove the two 4.5 mm screws.
    • Using a JIS #00 screwdriver, remove the two 4.5 mm screws.
  7. Disconnect the battery ribbon cable from bracket. Separate the chassis from the motherboard. Be careful with the battery ribbon cable, as it is very easy to break (ours did when disassembling).
    • Disconnect the battery ribbon cable from bracket.
    • Separate the chassis from the motherboard.
    • Be careful with the battery ribbon cable, as it is very easy to break (ours did when disassembling).
    • Note how the end of the ribbon cable seats in the plastic chassis. Look for the plastic pin on the chassis when re-seating.
    What happens if the battery ribbons breaks?
    sarah rus - 답글
    Hi the ribbon has come away from the mother board. How do I stick it back on? What type of adhesive do I use?
    Peter Alderson -
    I also broke the ribbon for the motherboard. What adhesive should I use to reattach it
    danieljchoe - 답글
    Be very careful with a ribbon that cannot come off on the opposite side of the red box on the motherboard when preforming this step. I found this and managed to avoid it.
    Andrew Watson - 답글
  8. Separate the battery from the motherboard. The battery and the motherboard are secured with adhesive; some force is needed.
    • Separate the battery from the motherboard.
    • The battery and the motherboard are secured with adhesive; some force is needed.
    • Lithium-ion batteries are potentially dangerous. Handle with extreme care and do not puncture the battery.
    I just used this guide to do a replacement, the watch works perfect now. Pay attention to whats in your hand vs whats on the guide a couple of the steps are not as straightforward just take your time. Overall good guide though.
    Michael Carlson - 답글
    Replaced the battery successfully with this guide. Take your time to carefully see whats on the watch compared to the guide.
    I removed the battery ribbon cable in step 7 by using a really small flat screwdriver to lift the cable from the housing. It's attached with adhesive tape.
    Eric Mulder - 답글
    Perfect. I just remove the two bolts form step 6. Battery was a little difficult to remove due to a tape that attached it on board.
    Works very well.
    Gabriel Pinho - 답글
    It took an extra tool that isn’t mentioned (very small, thin, straight screw driver), but it took only 20 minutes! Great step by step instructions!
    Walker - 답글
  9. When reassembling, place the battery into the plastic assembly first. Don’t stick it to the adhesive first. This way, it’s easy to position the battery cable. When securing the battery cable, make sure the hole that the peg goes through is round. The hole on your replacement battery’s cable could be malformed. You may want to widen the hole before securing the cable.
    • When reassembling, place the battery into the plastic assembly first. Don’t stick it to the adhesive first. This way, it’s easy to position the battery cable.
    • When securing the battery cable, make sure the hole that the peg goes through is round. The hole on your replacement battery’s cable could be malformed. You may want to widen the hole before securing the cable.
    • To widen the hole, use the Pro Tek Toolkit’s SIM tool, a small paperclip or similar fine-tipped tool. The tool can also be used to gently press the battery cable into the correct position. Do this carefully to avoid damage.
    • Follow steps 8-1 in reverse order to reassmble.
  10. Remove the battery's cable from the chassis using tweezers. Remove the battery's cable from the chassis using tweezers. Remove the battery's cable from the chassis using tweezers.
    • Remove the battery's cable from the chassis using tweezers.
결론
다른 3명이 해당 안내서를 완성하였습니다.
William Hurty
회원 가입일: 2018년 10월 08일
1,915 평판
안내서 3개 작성하였습니다
Cal Poly, Team S15-G2, White Fall 2018 Cal Poly, Team S15-G2, White Fall 2018 회원
CPSU-WHITE-F18S15G2
4 회원들
안내서 33개 작성하였습니다
Where can I purchase a motherboard for my Samsung Gears s3. Cant seem to find them
Mel Swint - 답글
Need motherboard for samsung gears
Mel Swint - 답글
Hello I was in MRI and my watch was unresponsive. What is the problem?
Shaymaa - 답글
My button Ribbon on my Mainboard has come detached. It seams like there was some adhesive holding it on so i pressed it together. put it back together but the buttons wont turn the watch on. it is charged. I can’t tell if the Ribbon was soldered on or some adhesive used to make those connections. Any help would be appreciated.
Rollins Gamer - 답글
I have the have the same issue! I replaced my battery, accidentally removed the power flex ribbon (the one with the power buttons) i bought two replacements, tried both, my watch won’t turn on. It does charge still and the LCD works, just doesn’t turn on. :\
Sal - 답글
EDIT: Just after posting this comment 10m ago, I took another look at the watch. You need to make sure the power flex ribbon is FLUSHED on the connectors on the board. I used scotch tape to test this theory and my watch turned on no problem. Consider getting circuit board adhesive from your local tech store for a cleaner install.
Sal - 답글
I also detached my ribbon. What did you guys do to reattach it?
danielhaugland13 - 답글
I found this : https://www.aliexpress.com/item/33051329...
But what about the software? will it be installed in the board? If i buy a mainboard from aliexpress will samsung allow me to update it?
Jubayer Bin Sayeed - 답글
quisiera saber si cambiando la placa madre se puede acceder ya que tiene una cuenta y no me deja restablecer de fábrica se restablece pero vuelve a aparecer todo de nuevo
chucky77_88 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 57
30일 전: 297
전체 시간: 10,359
