이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Wedge the metal spudger in between the back cover and the frame along the seam.
Use force to pry the back cover away from the main watch frame.
Disconnect the battery ribbon cable from bracket.
Separate the chassis from the motherboard.
When reassembling, place the battery into the plastic assembly first. Don’t stick it to the adhesive first. This way, it’s easy to position the battery cable.
When securing the battery cable, make sure the hole that the peg goes through is round. The hole on your replacement battery’s cable could be malformed. You may want to widen the hole before securing the cable.
To widen the hole, use the Pro Tech Toolkit’s SIM tool, a small paperclip or similar fine-tipped tool. The tool can also be used to gently press the battery cable into the correct position. Do this carefully to avoid damage.
Follow steps 8-1 in reverse order to reassmble.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 11개
Try ebay Mel
My button Ribbon on my Mainboard has come detached. It seams like there was some adhesive holding it on so i pressed it together. put it back together but the buttons wont turn the watch on. it is charged. I can’t tell if the Ribbon was soldered on or some adhesive used to make those connections. Any help would be appreciated.
