소개
Wenn die Rückabdeckung gebrochen oder beschädigt ist, benutze diese Anleitung, um sie zu ersetzen. Durch diesen Schritt wird die wasserfeste Dichtung beschädigt. Sei ausdauernd, da viel Zeit und Kraft erforderlich ist, um den Klebstoff zu lösen.
필요한 것
Lege die Uhr mit dem Zifferblatt nach unten, um an die Rückseite heranzukommen.
Folge diesen Anweisungen in umgekehrter Reihenfolge, um dein Gerät wieder zusammenzubauen.
다른 17명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 10개
How do I ensure the watch will be waterproof again?
Doesn’t sound like anything a careful application of RTV can’t handle. It can be found in small squeeze tubes at most auto parts stores, where it might be sold as ‘liquid gasket’ or something similar. You can also get it at hardware stores in large tubes meant to be used in caulking guns.
If the original gasket still looks good, no cracks or breaks in it after you remove the cover, I’d wager it will still be water proof after you put it back on. If it’s damaged, I would try to remove it entirely, and likewise, if the replacement cover doesn’t have a seal, you would want to apply some RTV or similar sealant. Ideally, I would use a syringe for this. In the US at least, you can buy needles at a pharmacy without a prescription, you just have to ask for them at the pharmacy counter. Suck some RTV into the syringe, and apply it carefully on the sealing surfaces of the cover. Put the cover on before the RTV dries so it mates to the surfaces, give it about an hour to cure, and it should be water proof.
Will the watch be waterproof again once the new back is installed!??
The back case of the watch contains an integrated rubberised o-ring.
Force is best applied by taking the band off and working at the edges adjacent to where the band meets the case.
There are small lips here where the thin metal Jimmy can be used to pry the case off with patience and low force by alternating between each end of the case.
The metal spudger tool recommded by this guide is the wrong tool for the job. The ends are far too thick.
Jimmy used: Jimmy
I lost 1 screw for the back cover. Where can I get a replacement? I measured the screw. Body Ø.045” x Length .133” x Head Ø.072. Metric conversion probably screw size M1.2 x 3.5mm lg. Any help would be greatly appreciated. Thanks
