주요 콘텐츠로 건너뛰기
Samsung Gear S3 Frontier Wristband Replacement
동영상 개요
  1. Samsung Gear S3 Frontier Wristband  Replacement, Wristband: 1 단계, 이미지 1/3 Samsung Gear S3 Frontier Wristband  Replacement, Wristband: 1 단계, 이미지 2/3 Samsung Gear S3 Frontier Wristband  Replacement, Wristband: 1 단계, 이미지 3/3
    • Place the watch screen-down so that its back cover is showing.
    • Use your nail to push the small silver ball bearing on the right side downward.
    • If your nails aren't sharp enough, you can use a sharp pointed object such as a toothpick or pen.
    • While the ball is pressed down, pull the wristband outwards until the strap is disconnected from the main frame.
    • For reassembly, hold the ball down and then wedge each pin on the wristband into the pin holes of the main frame.
    • Follow the same steps for the ball on the left side, except this time push the ball upwards and then pull outwards.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Corey Rumbaugh
회원 가입일: 10/08/18
1,517 평판
안내서 1개 작성함
Cal Poly, Team S15-G2, White Fall 2018 Cal Poly, Team S15-G2, White Fall 2018 회원
CPSU-WHITE-F18S15G2
4 회원들
안내서 34개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 36
전체 시간: 2,829
