주요 콘텐츠로 건너뛰기
Samsung Gear VR Motherboard Replacement
필요한 것
  1. Samsung Gear VR  Motherboard Replacement, Front Phone Mount: 1 단계, 이미지 1/3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: 1 단계, 이미지 2/3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: 1 단계, 이미지 3/3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR  Motherboard Replacement: 2 단계, 이미지 1/2 Samsung Gear VR  Motherboard Replacement: 2 단계, 이미지 2/2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR  Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR  Motherboard Replacement: 4 단계, 이미지 1/1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
결론
David Forlano
회원 가입일: 09/25/17
119 평판
안내서 1개 작성함
USF Tampa, Team S4-G6, Eyestone Fall 2017 USF Tampa, Team S4-G6, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G6
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
Any idea where I can get a replacement board? Searched but cant seem to find. Thanks!
bineesh2k - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 1,517
