주요 콘텐츠로 건너뛰기
Samsung Gear VR Focus Wheel Replacement
필요한 것
  1. Samsung Gear VR Focus Wheel Replacement, Front Phone Mount: 1 단계, 이미지 1/3 Samsung Gear VR Focus Wheel Replacement, Front Phone Mount: 1 단계, 이미지 2/3 Samsung Gear VR Focus Wheel Replacement, Front Phone Mount: 1 단계, 이미지 3/3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR Focus Wheel Replacement: 2 단계, 이미지 1/2 Samsung Gear VR Focus Wheel Replacement: 2 단계, 이미지 2/2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR Focus Wheel Replacement, Motherboard: 3 단계, 이미지 1/1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR Focus Wheel Replacement: 4 단계, 이미지 1/1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
  5. Samsung Gear VR Focus Wheel Replacement, Inner Mask: 5 단계, 이미지 1/3 Samsung Gear VR Focus Wheel Replacement, Inner Mask: 5 단계, 이미지 2/3 Samsung Gear VR Focus Wheel Replacement, Inner Mask: 5 단계, 이미지 3/3
    • Using the PH000 tip remove the eight 0.5 cm screws from the Inner Mask
    • Carefully remove the Inner Mask by pulling it from the inner side of the lenses socket.
  6. Samsung Gear VR Focus Wheel Replacement, Focus Wheel: 6 단계, 이미지 1/2 Samsung Gear VR Focus Wheel Replacement, Focus Wheel: 6 단계, 이미지 2/2
    • Use your fingers to gently remove focus wheel.
결론
Alfredo Aparicio
회원 가입일: 09/25/17
313 평판
안내서 3개 작성하였습니다
USF Tampa, Team S4-G6, Eyestone Fall 2017 USF Tampa, Team S4-G6, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G6
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
hi Alfredo, so my VR Oculus is blurry, I was wondering if u probably new what the problem was and if u could help me. I see u contributed to fixing some issues on the product.
August Tello - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 1,640
