주요 콘텐츠로 건너뛰기
Samsung Gear VR Front Phone Mount Replacement
필요한 것
  1. Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: 1 단계, 이미지 1/3 Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: 1 단계, 이미지 2/3 Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: 1 단계, 이미지 3/3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR Front Phone Mount Replacement: 2 단계, 이미지 1/2 Samsung Gear VR Front Phone Mount Replacement: 2 단계, 이미지 2/2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Garrett Moncrief
회원 가입일: 09/25/17
179 평판
안내서 1개 작성함
USF Tampa, Team S4-G6, Eyestone Fall 2017 USF Tampa, Team S4-G6, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G6
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 1,257
