소개
It is possible for the headset's lenses to become scratched, chipped, or simply dirty. The following guide will outline how to access the lenses for replacement or cleaning.
The motherboard partially sits on the inner mask piece of the headset and must be removed in order to remove the inner mask piece.
Caution is required while working on the headset as a wire harness connects the USB adapter to the motherboard. Care should be taken not to put any strain on the wire and to open the headset from right to left.
필요한 것
Remove the front cover to access a plate that holds the phone in place during use.
Remove the four corner screw covers with a metal spudger to reveal four screws.
Remove the sticker located at the top center to reveal two additional screws.
Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
Using the PH000 tip remove the eight 0.5 cm screws from the Inner Mask
Carefully remove the Inner Mask by pulling it from the inner side of the lenses socket.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
There are multiple mistakes in this tutorial, which made it hard to follow the steps:
- in step 2.1, you are missing 4 screws below each side of the latching mechanism.
- in step 5, the mask does not come apart after unscrewing the 8 screws. I am currently stuck at this step as I am writing this. Wish me luck.
