소개
The Samsung Gear VR supports Micro USB and USB-C ports. If your mobile device is unable to physically connect to the headset ensure that the adapter is the appropriate shape for your device's port. This guide will instruct you how to change which adapter is connected to the headset if needed.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 5개
Hola, quisiera saber donde se consigue esa parte, ni siquiera en samsung lo he logrado
Were do I get the USB c adapter
If you want USB c adapter I can give you…but we have to make exchange because I need micro usb adapter not type c
I have the micro USB adapter and need type c. Please advise as to how this barter may be executed?
Where can I get micro USB converter for gear vr not type c
