주요 콘텐츠로 건너뛰기
Samsung Gear VR with Controller Inner Mask Replacement
필요한 것
  1. Samsung Gear VR with Controller Inner Mask Replacement, Inner Mask: 1 단계, 이미지 1/3 Samsung Gear VR with Controller Inner Mask Replacement, Inner Mask: 1 단계, 이미지 2/3 Samsung Gear VR with Controller Inner Mask Replacement, Inner Mask: 1 단계, 이미지 3/3
    • Push the switch on the right-hand side of the device to separate the cover from the main body.
    • Pull the cover away from the main device.
  2. Samsung Gear VR with Controller Inner Mask Replacement: 2 단계, 이미지 1/3 Samsung Gear VR with Controller Inner Mask Replacement: 2 단계, 이미지 2/3 Samsung Gear VR with Controller Inner Mask Replacement: 2 단계, 이미지 3/3
    • Remove the four corner screw covers with a metal spudger.
    • The screw covers fly off when removed, so make sure to keep track of them.
  3. Samsung Gear VR with Controller Inner Mask Replacement: 3 단계, 이미지 1/3 Samsung Gear VR with Controller Inner Mask Replacement: 3 단계, 이미지 2/3 Samsung Gear VR with Controller Inner Mask Replacement: 3 단계, 이미지 3/3
    • Use a metal spudger to remove the screw cover centered at the top.
  4. Samsung Gear VR with Controller Inner Mask Replacement: 4 단계, 이미지 1/3 Samsung Gear VR with Controller Inner Mask Replacement: 4 단계, 이미지 2/3 Samsung Gear VR with Controller Inner Mask Replacement: 4 단계, 이미지 3/3
    • Remove the six 5mm Phillips #000 screws to detach the front phone mount.
    • Lift the front phone mount up and to the left.
    • Remove the front phone mount carefully because there is a wire harness on the left side of the headset.
  5. Samsung Gear VR with Controller Inner Mask Replacement: 5 단계, 이미지 1/2 Samsung Gear VR with Controller Inner Mask Replacement: 5 단계, 이미지 2/2
    • Remove the four 5mm Phillips #000 screws that secure the plate on the left side of the headset.
    • Pull the plate away from the motherboard gently.
  6. Samsung Gear VR with Controller Inner Mask Replacement: 6 단계, 이미지 1/2 Samsung Gear VR with Controller Inner Mask Replacement: 6 단계, 이미지 2/2
    • Use the iFixit opening tool to remove the pop connector holding the wire harness to the motherboard.
    • You can now completely remove the front phone mount from the headset.
  7. Samsung Gear VR with Controller Inner Mask Replacement: 7 단계, 이미지 1/3 Samsung Gear VR with Controller Inner Mask Replacement: 7 단계, 이미지 2/3 Samsung Gear VR with Controller Inner Mask Replacement: 7 단계, 이미지 3/3
    • Remove the rest of the pop connectors on the motherboard using the iFixit opening tool.
    • Pry at the top of the motherboard with the iFixit opening tool to remove the motherboard.
    • The largest pop connector may require more effort to remove.
    • Make sure that nothing is connected to the motherboard before you pull it out.
  8. Samsung Gear VR with Controller Inner Mask Replacement: 8 단계, 이미지 1/3 Samsung Gear VR with Controller Inner Mask Replacement: 8 단계, 이미지 2/3 Samsung Gear VR with Controller Inner Mask Replacement: 8 단계, 이미지 3/3
    • Remove the eight 5mm Phillips #000 screws on the inner mask.
    • Gently separate the inner mask from the headset by pulling the mask from the inner sides of the lens sockets.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Harumi Hokari
회원 가입일: 01/24/19
243 평판
안내서 2개 작성하였습니다
Cal Poly, Team S18-G3, White Winter 2019 Cal Poly, Team S18-G3, White Winter 2019 회원
CPSU-WHITE-W19S18G3
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 285
