주요 콘텐츠로 건너뛰기
Samsung Gear VR with Controller Motherboard Replacement
필요한 것
  1. Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: 1 단계, 이미지 1/3 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: 1 단계, 이미지 2/3 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: 1 단계, 이미지 3/3
    • Turn the controller upside down to access the battery compartment.
    • The battery compartment is located on the opposite side of the buttons.
    • Press on the top of the battery plate and slide down to remove the cover.
  2. Samsung Gear VR with Controller Motherboard Replacement: 2 단계, 이미지 1/3 Samsung Gear VR with Controller Motherboard Replacement: 2 단계, 이미지 2/3 Samsung Gear VR with Controller Motherboard Replacement: 2 단계, 이미지 3/3
    • Remove the AAA batteries using your fingers.
  3. Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: 3 단계, 이미지 1/2 Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: 3 단계, 이미지 2/2
    • Remove the four 5mm Phillips #000 screws.
  4. Samsung Gear VR with Controller Motherboard Replacement: 4 단계, 이미지 1/1
    • Use the metal spudger to pry the back side of the controller apart from the front.
    • You will have to use the spudger in many different spots along the divide before trying to separate the pieces.
  5. Samsung Gear VR with Controller Motherboard Replacement: 5 단계, 이미지 1/2 Samsung Gear VR with Controller Motherboard Replacement: 5 단계, 이미지 2/2
    • Pull apart the two halves of the controller to access the motherboard.
  6. Samsung Gear VR with Controller Motherboard Replacement: 6 단계, 이미지 1/3 Samsung Gear VR with Controller Motherboard Replacement: 6 단계, 이미지 2/3 Samsung Gear VR with Controller Motherboard Replacement: 6 단계, 이미지 3/3
    • Pry on the two pop connectors with the plastic opening tool to detach the motherboard.
    • Separate the motherboard and trackpad from the rear part of the controller.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jake Criscione
회원 가입일: 01/24/19
587 평판
안내서 3개 작성하였습니다
Cal Poly, Team S18-G3, White Winter 2019 Cal Poly, Team S18-G3, White Winter 2019 회원
CPSU-WHITE-W19S18G3
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 954
