메인 콘텐츠로 스킵하기
소개
This guide will provide a step by step procedure for installing the internal antenna.
부품
지정된 부품이 없습니다.
  1. Using your thumb, press down and slide the back cover away from the  camera.
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together. Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together.
    • Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together.
  5. Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap. Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap.
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
  6. The antenna is located on the bottom of the phone. It is the small rectangular shaped object sticking out on one of the ends. Use a plastic opening tool to prop the antenna out. To do so, slip the tip of the tool on one of the edges of the antenna. Use moderate pressure to pry the antenna out.
    • The antenna is located on the bottom of the phone. It is the small rectangular shaped object sticking out on one of the ends.
    • Use a plastic opening tool to prop the antenna out. To do so, slip the tip of the tool on one of the edges of the antenna. Use moderate pressure to pry the antenna out.
  7. Using a plastic opening tool, disconnect the connector leading from the antenna to the phone. Using a plastic opening tool, disconnect the connector leading from the antenna to the phone.
    • Using a plastic opening tool, disconnect the connector leading from the antenna to the phone.
결론
Cameron Law
회원 가입일: 2011년 10월 12일
142 평판
안내서 5개 작성하였습니다
Cal Poly, Team 3-12, Regan Fall 2011 Cal Poly, Team 3-12, Regan Fall 2011 회원
CPSU-REGAN-F11S3G12
4 회원들
안내서 14개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 984
