주요 콘텐츠로 건너뛰기
Samsung Glyde Camera Replacement
필요한 것
  1. Samsung Glyde Camera Replacement, Battery: 1 단계, 이미지 1/1
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Samsung Glyde Camera Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. Samsung Glyde Camera Replacement, Motherboard: 3 단계, 이미지 1/2 Samsung Glyde Camera Replacement, Motherboard: 3 단계, 이미지 2/2
    • Using a Phillips#00 screw driver, remove the six 4mm screws holding the back case together.
  4. Samsung Glyde Camera Replacement: 4 단계, 이미지 1/2 Samsung Glyde Camera Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
  5. Samsung Glyde Camera Replacement: 5 단계, 이미지 1/2 Samsung Glyde Camera Replacement: 5 단계, 이미지 2/2
    • The green film above the camera is the camera connector to the motherboard.
    • Use a plastic opening tool to disconnect the camera connector.
  6. Samsung Glyde Camera Replacement: 6 단계, 이미지 1/2 Samsung Glyde Camera Replacement: 6 단계, 이미지 2/2
    • The golden film connector connects the keyboard to the motherboard.
    • Use a plastic opening tool to disconnect the keyboard connector.
  7. Samsung Glyde Camera Replacement: 7 단계, 이미지 1/2 Samsung Glyde Camera Replacement: 7 단계, 이미지 2/2
    • The circular connector holds the motherboard in place.
    • Using a plastic opening tool, disconnect the circular connector.
  8. Samsung Glyde Camera Replacement: 8 단계, 이미지 1/3 Samsung Glyde Camera Replacement: 8 단계, 이미지 2/3 Samsung Glyde Camera Replacement: 8 단계, 이미지 3/3
    • There is a LCD connector underneath the motherboard.
    • Gently lift the far edge of the motherboard upwards toward the center of the phone.
    • Using a plastic opening tool, disconnect the LCD connector.
  9. Samsung Glyde Camera Replacement: 9 단계, 이미지 1/2 Samsung Glyde Camera Replacement: 9 단계, 이미지 2/2
    • After disconnecting the four connectors, gently lift the motherboard up with your fingers.
    • Place the motherboard in a secure area.
  10. Samsung Glyde Camera Replacement, Camera: 10 단계, 이미지 1/2 Samsung Glyde Camera Replacement, Camera: 10 단계, 이미지 2/2
    • Use your thumb and index finger to grip the camera connector.
    • Pull the camera connector upwards to detach the camera.
    • The camera was glued on, so this may require moderate strength.
결론
Cameron Law
회원 가입일: 10/12/11
142 평판
안내서 5개 작성하였습니다
Cal Poly, Team 3-12, Regan Fall 2011 Cal Poly, Team 3-12, Regan Fall 2011 회원
CPSU-REGAN-F11S3G12
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 877
