주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Glyde Motherboard Replacement
필요한 것
  1. Samsung Glyde Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Using your thumb, press down and slide the back cover away from the camera.
    댓글 쓰기
  2. Samsung Glyde Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
    댓글 쓰기
  3. Samsung Glyde Motherboard Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 Samsung Glyde Motherboard Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
    • Using a Phillips#00 screw driver, remove the six 4mm screws holding the back case together.
    댓글 쓰기
  4. Samsung Glyde Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Samsung Glyde Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
    댓글 쓰기
  5. Samsung Glyde Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Samsung Glyde Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • The green film above the camera is the camera connector to the motherboard.
    • Use a plastic opening tool to disconnect the camera connector.
    댓글 쓰기
  6. Samsung Glyde Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Samsung Glyde Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • The golden film connector connects the keyboard to the motherboard.
    • Use a plastic opening tool to disconnect the keyboard connector.
    댓글 쓰기
  7. Samsung Glyde Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Samsung Glyde Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • The circular connector holds the motherboard in place.
    • Using a plastic opening tool, disconnect the circular connector.
    댓글 쓰기
  8. Samsung Glyde Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Samsung Glyde Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Samsung Glyde Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • There is a LCD connector underneath the motherboard.
    • Gently lift the far edge of the motherboard upwards toward the center of the phone.
    • Using a plastic opening tool, disconnect the LCD connector.
    댓글 쓰기
  9. Samsung Glyde Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Samsung Glyde Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • After disconnecting the four connectors, gently lift the motherboard up with your fingers.
    • Place the motherboard in a secure area.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
9다른 기여자 명과 함께
Stephen
회원 가입일: 10/12/11
26 평판
안내서 1개를 작성함
Cal Poly, Team 3-12, Regan Fall 2011 Cal Poly, Team 3-12, Regan Fall 2011 회원
CPSU-REGAN-F11S3G12
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 17
지난 30일: 45
전체 시간: 1,466
