주요 콘텐츠로 건너뛰기
Samsung Gravity SGH-T669 Front Glass Assembly Replacement
필요한 것
  1. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Battery: 1 단계, 이미지 1/3 Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Battery: 1 단계, 이미지 2/3 Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure your phone is powered off.
    • Use a plastic opening tool to remove the rear battery cover.
  2. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 2 단계, 이미지 1/2 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 2 단계, 이미지 2/2
    • Remove the battery by pulling up from the bottom right corner.
    • Remove the SIM card and the Micro SD card.
    • SIM card
    • Micro SD card
  3. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Casing: 3 단계, 이미지 1/1
    • Remove the six 2.8 mm Phillips screws.
  4. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 4 단계, 이미지 1/3 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 4 단계, 이미지 2/3 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 4 단계, 이미지 3/3
    • Use a plastic opening tool to pry off the casing.
    • The volume button, camera button, and lock button may fall out as you remove the casing. If they are still on the phone, remove them.
    • Lock button
    • Camera button
    • Volume button
  5. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Motherboard: 5 단계, 이미지 1/2 Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Motherboard: 5 단계, 이미지 2/2
    • Disconnect the LCD cable with a plastic opening tool.
    • Remove the two 2.8 mm Phillips screws that hold the motherboard in place.
  6. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 6 단계, 이미지 1/1
    • Remove motherboard.
  7. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Separating the halves: 7 단계, 이미지 1/2 Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Separating the halves: 7 단계, 이미지 2/2
    • Remove the six 1.5 mm Phillips screws.
    • Very gently peel the LCD cord off the slider assembly.
  8. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 8 단계, 이미지 1/1
    • Remove the keyboard housing from the screen housing.
  9. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Screen casing: 9 단계, 이미지 1/1
    • Remove the four 2.5 mm Phillips screws.
  10. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 10 단계, 이미지 1/3 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 10 단계, 이미지 2/3 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 10 단계, 이미지 3/3
    • I found that my plastic opening tool wasn't strong enough (it broke) to pry open this casing.
    • I used a 1.3 mm Flathead screwdriver as an opening tool.
    • After you have gotten under the edge of the back plate, slide your tool along the length of the plate.
    • Be careful if using a screwdriver to open the casing. While there are a minimal amount of components that can be damaged, caution should be exercised. It is not recommended.
  11. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 11 단계, 이미지 1/2 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 11 단계, 이미지 2/2
    • Remove the cover.
    • There are four clips on the underside of the cover, shown in the green and yellow boxes.
    • I found these clips to be the hardest to remove.
    • After removing the yellow clips, these should follow easily.
  12. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Remove the LCD: 12 단계, 이미지 1/2 Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Remove the LCD: 12 단계, 이미지 2/2
    • It's time to take the LCD out.
    • Begin by removing the blue piece of tape.
  13. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 13 단계, 이미지 1/2 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 13 단계, 이미지 2/2
    • Disconnect the two ZIF connections using a plastic opening tool.
    • ZIF #1
    • ZIF #2
  14. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 14 단계, 이미지 1/1
    • Use a plastic opening tool on the bottom of the LCD to pry it off.
  15. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: 15 단계, 이미지 1/1
    • Remove the LCD panel.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Andrew Schneider
회원 가입일: 05/31/14
970 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 1,326
