주요 콘텐츠로 건너뛰기
Samsung Gravity TXT Battery Replacement
필요한 것
  1. Samsung Gravity TXT Battery Replacement, Battery: 1 단계, 이미지 1/2 Samsung Gravity TXT Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
  2. Samsung Gravity TXT Battery Replacement: 2 단계, 이미지 1/1
    • Lift the back cover away from the main body of the phone.
  3. Samsung Gravity TXT Battery Replacement: 3 단계, 이미지 1/1
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
결론
Mounir Karmada
회원 가입일: 07/07/15
465 평판
안내서 4개 작성하였습니다
IUPUI, Team 1-1, Renguette SU 2015 IUPUI, Team 1-1, Renguette SU 2015 회원
IUPUI-RENGUETTE-SU15S1G1
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 453
