소개
It is easier to replace the entire phone's motherboard than replacing one component of a complicated circuit such as a USB port, back camera or Sim Card slot.
필요한 것
Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
Using your finger, push the SIM Card down and slide out of the slot.
Remove the SIM card away from the phone.
Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
After the click, release the microSD card to allow it to pop out.
Remove the microSD card from its slot
Remove the two 3 mm Phillips #00 screws securing the motherboard to the front panel.
