주요 콘텐츠로 건너뛰기
Samsung Gusto 2 Speaker Replacement
필요한 것
  1. Samsung Gusto 2 Speaker Replacement, Speaker: 1 단계, 이미지 1/2 Samsung Gusto 2 Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Flip open the phone as shown in picture 1.
    • Remove the two screws highlighted in picture 1.
  2. Samsung Gusto 2 Speaker Replacement: 2 단계, 이미지 1/1
    • Take your spudger and forcefully insert it between the black and silver part of the phone.
    • Once the spudger is successfully wedged in between these two pieces, circle the frame of the phone.
  3. Samsung Gusto 2 Speaker Replacement: 3 단계, 이미지 1/2 Samsung Gusto 2 Speaker Replacement: 3 단계, 이미지 2/2
    • The phone should be exposed like picture 1 once the case was removed.
    • The highlighted sections correspond to the bullet colors. To replace either simply disconnect the wires attached, and lift the piece off.
    • Speaker Component
    • Vibration Component
결론
다른 2명이 해당 안내서를 완성하였습니다.
Michael Huang
회원 가입일: 03/30/15
403 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 2-5, Shastany Spring 2015 UMass Dartmouth, Team 2-5, Shastany Spring 2015 회원
UMASSD-SHASTANY-S15S2G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 559
