주요 콘텐츠로 건너뛰기
Samsung HMX-F90 LCD Screen Replacement
필요한 것
  1. Samsung HMX-F90 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/2 Samsung HMX-F90 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2/2
    • Rotate the camcorder so that back is facing you. Then flip open the LCD screen.
    • Locate and remove the 4.5mm Phillips #00 screws in the LCD screen base.
  2. Samsung HMX-F90 LCD Screen Replacement: 2 단계, 이미지 1/2 Samsung HMX-F90 LCD Screen Replacement: 2 단계, 이미지 2/2
    • Close the LCD screen. Then lift the silver base away from the camcorder.
  3. Samsung HMX-F90 LCD Screen Replacement: 3 단계, 이미지 1/2 Samsung HMX-F90 LCD Screen Replacement: 3 단계, 이미지 2/2
    • Rotate the camcorder so that it is facing you.
    • Locate and remove the two 4.5mm Phillips #00 screws.
  4. Samsung HMX-F90 LCD Screen Replacement: 4 단계, 이미지 1/3 Samsung HMX-F90 LCD Screen Replacement: 4 단계, 이미지 2/3 Samsung HMX-F90 LCD Screen Replacement: 4 단계, 이미지 3/3
    • Open the LCD screen and rotate it around 90 degrees.
    • Locate the small prying notch and use a prying tool to slowly remove the LCD cover.
  5. Samsung HMX-F90 LCD Screen Replacement: 5 단계, 이미지 1/3 Samsung HMX-F90 LCD Screen Replacement: 5 단계, 이미지 2/3 Samsung HMX-F90 LCD Screen Replacement: 5 단계, 이미지 3/3
    • Locate and remove the two 3.5mm Phillips #00 screws holding the back cover.
  6. Samsung HMX-F90 LCD Screen Replacement: 6 단계, 이미지 1/3 Samsung HMX-F90 LCD Screen Replacement: 6 단계, 이미지 2/3 Samsung HMX-F90 LCD Screen Replacement: 6 단계, 이미지 3/3
    • With tweezers gently unclip the silver tab holding the ribbon wire.
    • Gradually feed the ribbon wire through the hole to remove the screen.
결론
Amir Harb
회원 가입일: 09/26/17
705 평판
안내서 6개 작성하였습니다
USF Tampa, Team S13-G1, Boczar Fall 2017 USF Tampa, Team S13-G1, Boczar Fall 2017 회원
USFT-BOCZAR-F17S13G1
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
How can I buy the LCD??
Mike - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 34
전체 시간: 1,095
