주요 콘텐츠로 건너뛰기
Samsung HMX-F90 Lens Replacement
필요한 것
  1. Samsung HMX-F90 Lens Replacement, Battery: 1 단계, 이미지 1/3 Samsung HMX-F90 Lens Replacement, Battery: 1 단계, 이미지 2/3 Samsung HMX-F90 Lens Replacement, Battery: 1 단계, 이미지 3/3
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Samsung HMX-F90 Lens Replacement, Strap Side Outer Casing: 2 단계, 이미지 1/2 Samsung HMX-F90 Lens Replacement, Strap Side Outer Casing: 2 단계, 이미지 2/2
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. Samsung HMX-F90 Lens Replacement: 3 단계, 이미지 1/2 Samsung HMX-F90 Lens Replacement: 3 단계, 이미지 2/2
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. Samsung HMX-F90 Lens Replacement: 4 단계, 이미지 1/2 Samsung HMX-F90 Lens Replacement: 4 단계, 이미지 2/2
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. Samsung HMX-F90 Lens Replacement: 5 단계, 이미지 1/3 Samsung HMX-F90 Lens Replacement: 5 단계, 이미지 2/3 Samsung HMX-F90 Lens Replacement: 5 단계, 이미지 3/3
    • With both hands, pull the side strap apart from the rest of the camcorder.
  6. Samsung HMX-F90 Lens Replacement, Lens: 6 단계, 이미지 1/2 Samsung HMX-F90 Lens Replacement, Lens: 6 단계, 이미지 2/2
    • Rotate the camcorder so that back is facing you. Then flip open the LCD screen.
    • Locate and remove the 4.5mm Phillips #00 screws in the LCD screen base.
  7. Samsung HMX-F90 Lens Replacement: 7 단계, 이미지 1/2 Samsung HMX-F90 Lens Replacement: 7 단계, 이미지 2/2
    • Close the LCD screen. Then lift the silver base away from the camcorder.
  8. Samsung HMX-F90 Lens Replacement: 8 단계, 이미지 1/2 Samsung HMX-F90 Lens Replacement: 8 단계, 이미지 2/2
    • Locate and remove the two 3.5mm Phillips #00 screws from the side of the camcorder.
  9. Samsung HMX-F90 Lens Replacement: 9 단계, 이미지 1/3 Samsung HMX-F90 Lens Replacement: 9 단계, 이미지 2/3 Samsung HMX-F90 Lens Replacement: 9 단계, 이미지 3/3
    • Gradually pry off the outer casing using a prying tool.
  10. Samsung HMX-F90 Lens Replacement: 10 단계, 이미지 1/3 Samsung HMX-F90 Lens Replacement: 10 단계, 이미지 2/3 Samsung HMX-F90 Lens Replacement: 10 단계, 이미지 3/3
    • Locate and remove the three 4mm Phillips #00 screws around the lens.
    • Gently remove the lens.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Amir Harb
회원 가입일: 09/26/17
705 평판
안내서 6개 작성하였습니다
USF Tampa, Team S13-G1, Boczar Fall 2017 USF Tampa, Team S13-G1, Boczar Fall 2017 회원
USFT-BOCZAR-F17S13G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 23
전체 시간: 1,173
