주요 콘텐츠로 건너뛰기
Samsung HMX-F90 Strap Replacement
필요한 것
  1. Samsung HMX-F90 Strap Replacement, Battery: 1 단계, 이미지 1/3 Samsung HMX-F90 Strap Replacement, Battery: 1 단계, 이미지 2/3 Samsung HMX-F90 Strap Replacement, Battery: 1 단계, 이미지 3/3
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Samsung HMX-F90 Strap Replacement, Strap Side Outer Casing: 2 단계, 이미지 1/2 Samsung HMX-F90 Strap Replacement, Strap Side Outer Casing: 2 단계, 이미지 2/2
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. Samsung HMX-F90 Strap Replacement: 3 단계, 이미지 1/2 Samsung HMX-F90 Strap Replacement: 3 단계, 이미지 2/2
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. Samsung HMX-F90 Strap Replacement: 4 단계, 이미지 1/2 Samsung HMX-F90 Strap Replacement: 4 단계, 이미지 2/2
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. Samsung HMX-F90 Strap Replacement: 5 단계, 이미지 1/3 Samsung HMX-F90 Strap Replacement: 5 단계, 이미지 2/3 Samsung HMX-F90 Strap Replacement: 5 단계, 이미지 3/3
    • With both hands, pull the side strap apart from the rest of the camcorder.
  6. Samsung HMX-F90 Strap Replacement, Hand Strap: 6 단계, 이미지 1/3 Samsung HMX-F90 Strap Replacement, Hand Strap: 6 단계, 이미지 2/3 Samsung HMX-F90 Strap Replacement, Hand Strap: 6 단계, 이미지 3/3
    • Unfasten the strap from the outside.
    • Pull apart the velcro on the faux leather strap sheath to reveal the separate end of the strap.
    • The loose end can be pulled off the velcro and fed through the loop on the casing to free one end of the strap.
  7. Samsung HMX-F90 Strap Replacement: 7 단계, 이미지 1/3 Samsung HMX-F90 Strap Replacement: 7 단계, 이미지 2/3 Samsung HMX-F90 Strap Replacement: 7 단계, 이미지 3/3
    • On the inside of the opened case, locate the silver metal plate and remove the 3mm Phillips screw.
    • Feed the strap through the hole to remove completely so that it can be replaced or cleaned.
결론
Amir Harb
회원 가입일: 09/26/17
705 평판
안내서 6개 작성하였습니다
USF Tampa, Team S13-G1, Boczar Fall 2017 USF Tampa, Team S13-G1, Boczar Fall 2017 회원
USFT-BOCZAR-F17S13G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 17
전체 시간: 290
