소개
Overtime velcro on the strap will become worn out which can cause the HMX-F90 to become difficult to hold. This guide can be used to replace the worn out hand strap.
필요한 것
Pull the release tab away from the battery.
Slide the battery towards the release tab and then pull the battery away from the camcorder.
Rotate the camcorder so that the strap side is facing you.
Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
Unfasten the strap from the outside.
Pull apart the velcro on the faux leather strap sheath to reveal the separate end of the strap.
The loose end can be pulled off the velcro and fed through the loop on the casing to free one end of the strap.
