주요 콘텐츠로 건너뛰기
Samsung HMX-QF20 Internal Microphone Replacement
필요한 것
  1. Samsung HMX-QF20 Internal Microphone Replacement, Lens: 1 단계, 이미지 1/1
    • Remove the 4 mm screw on the underside of the camcorder near the tripod mount.
  2. Samsung HMX-QF20 Internal Microphone Replacement: 2 단계, 이미지 1/1
    • Remove the 4 mm screw next to the buckle of the hand strap closest to the lens.
  3. Samsung HMX-QF20 Internal Microphone Replacement: 3 단계, 이미지 1/1
    • Open the LCD screen. Remove the 4 mm screw on the inside panel, located at top left corner.
  4. Samsung HMX-QF20 Internal Microphone Replacement: 4 단계, 이미지 1/1
    • Firmly grip and pull the front casing on the lens to remove it.
    • Be sure to remove the front casing at gently as possible to prevent damaging the attached ribbon cable. If not careful, the ribbon cables could be torn.
  5. Samsung HMX-QF20 Internal Microphone Replacement: 5 단계, 이미지 1/1
    • Remove the three 5 mm screws surrounding the lens.
결론
Ian Dorset
회원 가입일: 03/11/15
225 평판
안내서 2개 작성하였습니다
Marist, Team 1-5, Laflen Spring 2015 Marist, Team 1-5, Laflen Spring 2015 회원
MARS-LAFLEN-S15S1G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 385
