주요 콘텐츠로 건너뛰기
Samsung HMX-W200 Camera Lens Replacement
필요한 것
  1. Samsung HMX-W200 Camera Lens Replacement, Outer Case: 1 단계, 이미지 1/1
    • Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
  2. Samsung HMX-W200 Camera Lens Replacement: 2 단계, 이미지 1/3 Samsung HMX-W200 Camera Lens Replacement: 2 단계, 이미지 2/3 Samsung HMX-W200 Camera Lens Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to separate and remove the bottom red casing. Do this by, pushing the tool into the seam and prying up the red casing as you move along the edges.
    • Make sure to separate all the corners before removing the red casing.
  3. Samsung HMX-W200 Camera Lens Replacement: 3 단계, 이미지 1/2 Samsung HMX-W200 Camera Lens Replacement: 3 단계, 이미지 2/2
    • Using the plastic opening tool, separate and pull away the red casing on the right of the LCD screen.
  4. Samsung HMX-W200 Camera Lens Replacement: 4 단계, 이미지 1/2 Samsung HMX-W200 Camera Lens Replacement: 4 단계, 이미지 2/2
    • To access the HDMI slot, move slider towards the bottom of the casing on the other side of the camcorder. The lid casing will lift up upon doing so.
    • After accessing the HDMI slot you will find a 5.00mm screw. Using a Phillips #00 screwdriver, remove the screw.
  5. Samsung HMX-W200 Camera Lens Replacement: 5 단계, 이미지 1/2 Samsung HMX-W200 Camera Lens Replacement: 5 단계, 이미지 2/2
    • Using the plastic opening tool, separate and pull away the red casing to the left of the LCD screen.
  6. Samsung HMX-W200 Camera Lens Replacement: 6 단계, 이미지 1/2 Samsung HMX-W200 Camera Lens Replacement: 6 단계, 이미지 2/2
    • Remove the six 5.00mm screws by using a Phillips #00 screwdriver.
  7. Samsung HMX-W200 Camera Lens Replacement: 7 단계, 이미지 1/3 Samsung HMX-W200 Camera Lens Replacement: 7 단계, 이미지 2/3 Samsung HMX-W200 Camera Lens Replacement: 7 단계, 이미지 3/3
    • Lift the two plastic tabs on the left side of the LCD screen and the single one on the right side on the black casing to open the device.
  8. Samsung HMX-W200 Camera Lens Replacement: 8 단계, 이미지 1/1
    • Separate the front and back casing.
  9. Samsung HMX-W200 Camera Lens Replacement, Motherboard: 9 단계, 이미지 1/1
    • Once inside the device, find the half that contains the motherboard of the device.
  10. Samsung HMX-W200 Camera Lens Replacement: 10 단계, 이미지 1/1
    • Use precision tweezers to gently pull out the USB connection from the motherboard.
  11. Samsung HMX-W200 Camera Lens Replacement: 11 단계, 이미지 1/2 Samsung HMX-W200 Camera Lens Replacement: 11 단계, 이미지 2/2
    • Remove the audio connector from the motherboard (red and black cables).
    • Using the plastic opening tool, lift the connectors from all sides before pulling it with your fingers.
    • Do not pull off the connectors by the cables. This could damage the connection from the speaker to the motherboard.
  12. Samsung HMX-W200 Camera Lens Replacement: 12 단계, 이미지 1/2 Samsung HMX-W200 Camera Lens Replacement: 12 단계, 이미지 2/2
    • Use precision tweezers to remove the connector joining the LCD and the motherboard.
  13. Samsung HMX-W200 Camera Lens Replacement: 13 단계, 이미지 1/2 Samsung HMX-W200 Camera Lens Replacement: 13 단계, 이미지 2/2
    • Remove the six 2.00mm screws with Phillips #00 screwdriver.
  14. Samsung HMX-W200 Camera Lens Replacement: 14 단계, 이미지 1/3 Samsung HMX-W200 Camera Lens Replacement: 14 단계, 이미지 2/3 Samsung HMX-W200 Camera Lens Replacement: 14 단계, 이미지 3/3
    • Lift motherboard from top left side and pull away gently.
  15. Samsung HMX-W200 Camera Lens Replacement, Camera Lens: 15 단계, 이미지 1/1
    • Use the precision tweezers, to gently pull and remove the connector connecting lens and motherboard.
  16. Samsung HMX-W200 Camera Lens Replacement: 16 단계, 이미지 1/2 Samsung HMX-W200 Camera Lens Replacement: 16 단계, 이미지 2/2
    • Using the precision tweezers, lift silver heat sync tape from motherboard.
  17. Samsung HMX-W200 Camera Lens Replacement: 17 단계, 이미지 1/2 Samsung HMX-W200 Camera Lens Replacement: 17 단계, 이미지 2/2
    • Turn the motherboard over.
    • Use Phillips #00 screwdriver to unscrew four 4mm screws holding the camera lens to the motherboard.
  18. Samsung HMX-W200 Camera Lens Replacement: 18 단계, 이미지 1/2 Samsung HMX-W200 Camera Lens Replacement: 18 단계, 이미지 2/2
    • Gently grab the lens with your fingers and pull it away from the motherboard.
    • Camera lens should easily come off the motherboard when the last screw is loose.
결론
Haya Barakat
회원 가입일: 10/04/16
521 평판
안내서 5개 작성하였습니다
USF Tampa, Team 3-6, Sullivan Fall 2016 USF Tampa, Team 3-6, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S3G6
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 187
