소개
For this replacement, the user will need to remove the outer casing. Then remove the motherboard. After, they will be able to begin the replacement process of the control buttons.
필요한 것
Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
Once inside the device, find the half that contains the motherboard of the device.
Locate the metal plate under the motherboard. This plate should be removed.
Use a Phillips head #00 screwdriver to remove eleven 5mm screws.
