소개
To begin the replacement process for the speaker, the user will need to remove the outer casing. Then remove the motherboard, this will allow them to get to the speaker.
필요한 것
Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
Once inside the device, find the half that contains the motherboard of the device.
Under the motherboard there is a metal plate that has to be removed.
Use a Phillips head #00 screwdriver to remove eleven 5mm screws.
거의 끝나갑니다!
결론
