주요 콘텐츠로 건너뛰기
Samsung HMX-W300 Battery Replacement
필요한 것
  1. Samsung HMX-W300 Battery Replacement, Disassembling Samsung HMX-W300: 1 단계, 이미지 1/3 Samsung HMX-W300 Battery Replacement, Disassembling Samsung HMX-W300: 1 단계, 이미지 2/3 Samsung HMX-W300 Battery Replacement, Disassembling Samsung HMX-W300: 1 단계, 이미지 3/3
    • To remove the wristband of the device, grab the middle loop and pull the band through.
  2. Samsung HMX-W300 Battery Replacement: 2 단계, 이미지 1/2 Samsung HMX-W300 Battery Replacement: 2 단계, 이미지 2/2
    • Remove four screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 Battery Replacement: 3 단계, 이미지 1/3 Samsung HMX-W300 Battery Replacement: 3 단계, 이미지 2/3 Samsung HMX-W300 Battery Replacement: 3 단계, 이미지 3/3
    • Open the HDMI door on the side of the camera.
    • Remove the single screw using a Phillips #00 screwdriver.
  4. Samsung HMX-W300 Battery Replacement: 4 단계, 이미지 1/3 Samsung HMX-W300 Battery Replacement: 4 단계, 이미지 2/3 Samsung HMX-W300 Battery Replacement: 4 단계, 이미지 3/3
    • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 Battery Replacement: 5 단계, 이미지 1/3 Samsung HMX-W300 Battery Replacement: 5 단계, 이미지 2/3 Samsung HMX-W300 Battery Replacement: 5 단계, 이미지 3/3
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 Battery Replacement, Battery: 6 단계, 이미지 1/2 Samsung HMX-W300 Battery Replacement, Battery: 6 단계, 이미지 2/2
    • Remove the four screws from the battery housing using a Phillips #00 screwdriver.
  7. Samsung HMX-W300 Battery Replacement: 7 단계, 이미지 1/1
    • Use the iFixit opening tool to pry the battery housing open.
  8. Samsung HMX-W300 Battery Replacement: 8 단계, 이미지 1/3 Samsung HMX-W300 Battery Replacement: 8 단계, 이미지 2/3 Samsung HMX-W300 Battery Replacement: 8 단계, 이미지 3/3
    • After removing the battery housing, take the battery out.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Robert
회원 가입일: 01/21/15
966 평판
안내서 8개 작성하였습니다
USF Tampa, Team 9-2, Blackwell Winter 2015 USF Tampa, Team 9-2, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G2
4 회원들
안내서 16개 작성하였습니다
댓글 2개
What type of battery is this? What part number should we use to order a replacement?
VanDemark - 답글
The type of battery should be printed on the case of the battery. Most likely it’s some type of lithium battery. The part number for the battery should be on the case as well. If you can’t find either of these on the battery case you can take the battery to a place that sales batteries and the personnel there should be able to tell you the type and part number for your battery.
Jarretti Reaves -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 2,111
