주요 콘텐츠로 건너뛰기
Samsung HMX-W300 Rear Case Replacement
필요한 것
  1. Samsung HMX-W300 Rear Case Replacement, Disassembling Samsung HMX-W300: 1 단계, 이미지 1/3 Samsung HMX-W300 Rear Case Replacement, Disassembling Samsung HMX-W300: 1 단계, 이미지 2/3 Samsung HMX-W300 Rear Case Replacement, Disassembling Samsung HMX-W300: 1 단계, 이미지 3/3
    • To remove the wristband of the device, grab the middle loop and pull the band through.
  2. Samsung HMX-W300 Rear Case Replacement: 2 단계, 이미지 1/2 Samsung HMX-W300 Rear Case Replacement: 2 단계, 이미지 2/2
    • Remove four screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 Rear Case Replacement: 3 단계, 이미지 1/3 Samsung HMX-W300 Rear Case Replacement: 3 단계, 이미지 2/3 Samsung HMX-W300 Rear Case Replacement: 3 단계, 이미지 3/3
    • Open the HDMI door on the side of the camera.
    • Remove the single screw using a Phillips #00 screwdriver.
  4. Samsung HMX-W300 Rear Case Replacement: 4 단계, 이미지 1/3 Samsung HMX-W300 Rear Case Replacement: 4 단계, 이미지 2/3 Samsung HMX-W300 Rear Case Replacement: 4 단계, 이미지 3/3
    • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 Rear Case Replacement: 5 단계, 이미지 1/3 Samsung HMX-W300 Rear Case Replacement: 5 단계, 이미지 2/3 Samsung HMX-W300 Rear Case Replacement: 5 단계, 이미지 3/3
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 Rear Case Replacement, Remove tape.: 6 단계, 이미지 1/3 Samsung HMX-W300 Rear Case Replacement, Remove tape.: 6 단계, 이미지 2/3 Samsung HMX-W300 Rear Case Replacement, Remove tape.: 6 단계, 이미지 3/3
    • Use tweezers to remove the tape.
  7. Samsung HMX-W300 Rear Case Replacement, Unplug wire ribbon.: 7 단계, 이미지 1/2 Samsung HMX-W300 Rear Case Replacement, Unplug wire ribbon.: 7 단계, 이미지 2/2
    • Use tweezers to grab the wire ribbon, then pull the wire out of connection.
  8. Samsung HMX-W300 Rear Case Replacement, Remove scerws.: 8 단계, 이미지 1/2 Samsung HMX-W300 Rear Case Replacement, Remove scerws.: 8 단계, 이미지 2/2
    • There are 5 Phillips size 00 screws. Remove all 5 screws.
    • Wire ribbon is attached to the motherboard.
  9. Samsung HMX-W300 Rear Case Replacement: 9 단계, 이미지 1/1
    • Pry the motherboard up using the plastic opening tool.
    • Be careful there is a wire ribbon holding the motherboard.
  10. Samsung HMX-W300 Rear Case Replacement, Disconnect wire ribbon.: 10 단계, 이미지 1/2 Samsung HMX-W300 Rear Case Replacement, Disconnect wire ribbon.: 10 단계, 이미지 2/2
    • Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
  11. Samsung HMX-W300 Rear Case Replacement, Remove screws.: 11 단계, 이미지 1/3 Samsung HMX-W300 Rear Case Replacement, Remove screws.: 11 단계, 이미지 2/3 Samsung HMX-W300 Rear Case Replacement, Remove screws.: 11 단계, 이미지 3/3
    • Use Phillips size 00 and remove the 3 screws as shown.
  12. Samsung HMX-W300 Rear Case Replacement, Pry screen.: 12 단계, 이미지 1/2 Samsung HMX-W300 Rear Case Replacement, Pry screen.: 12 단계, 이미지 2/2
    • Pry the end of the screen with the plastic opening tool.
  13. Samsung HMX-W300 Rear Case Replacement: 13 단계, 이미지 1/3 Samsung HMX-W300 Rear Case Replacement: 13 단계, 이미지 2/3 Samsung HMX-W300 Rear Case Replacement: 13 단계, 이미지 3/3
    • Grab the end of the screen, then pull towards the inside of the case. This is a bit tricky. This will release tabs at the top of the screen to the rear case.
  14. Samsung HMX-W300 Rear Case Replacement, Repalce rear case: 14 단계, 이미지 1/1
    • Removal of the rear case is completed.
결론
Robert
회원 가입일: 01/21/15
966 평판
안내서 8개 작성하였습니다
USF Tampa, Team 9-2, Blackwell Winter 2015 USF Tampa, Team 9-2, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G2
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 246
