주요 콘텐츠로 건너뛰기
Samsung HMX-W300 USB Port Replacement
필요한 것
  1. Samsung HMX-W300 USB Port Replacement, Disassembling Samsung HMX-W300: 1 단계, 이미지 1/3 Samsung HMX-W300 USB Port Replacement, Disassembling Samsung HMX-W300: 1 단계, 이미지 2/3 Samsung HMX-W300 USB Port Replacement, Disassembling Samsung HMX-W300: 1 단계, 이미지 3/3
    • To remove the wristband of the device, grab the middle loop and pull the band through.
  2. Samsung HMX-W300 USB Port Replacement: 2 단계, 이미지 1/2 Samsung HMX-W300 USB Port Replacement: 2 단계, 이미지 2/2
    • Remove four screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 USB Port Replacement: 3 단계, 이미지 1/3 Samsung HMX-W300 USB Port Replacement: 3 단계, 이미지 2/3 Samsung HMX-W300 USB Port Replacement: 3 단계, 이미지 3/3
    • Open the HDMI door on the side of the camera.
    • Remove the single screw using a Phillips #00 screwdriver.
  4. Samsung HMX-W300 USB Port Replacement: 4 단계, 이미지 1/3 Samsung HMX-W300 USB Port Replacement: 4 단계, 이미지 2/3 Samsung HMX-W300 USB Port Replacement: 4 단계, 이미지 3/3
    • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 USB Port Replacement: 5 단계, 이미지 1/3 Samsung HMX-W300 USB Port Replacement: 5 단계, 이미지 2/3 Samsung HMX-W300 USB Port Replacement: 5 단계, 이미지 3/3
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 USB Port Replacement, Battery: 6 단계, 이미지 1/2 Samsung HMX-W300 USB Port Replacement, Battery: 6 단계, 이미지 2/2
    • Remove the four screws from the battery housing using a Phillips #00 screwdriver.
  7. Samsung HMX-W300 USB Port Replacement: 7 단계, 이미지 1/1
    • Use the iFixit opening tool to pry the battery housing open.
  8. Samsung HMX-W300 USB Port Replacement: 8 단계, 이미지 1/3 Samsung HMX-W300 USB Port Replacement: 8 단계, 이미지 2/3 Samsung HMX-W300 USB Port Replacement: 8 단계, 이미지 3/3
    • After removing the battery housing, take the battery out.
  9. Samsung HMX-W300 USB Port Replacement, USB Port: 9 단계, 이미지 1/3 Samsung HMX-W300 USB Port Replacement, USB Port: 9 단계, 이미지 2/3 Samsung HMX-W300 USB Port Replacement, USB Port: 9 단계, 이미지 3/3
    • Use an iFixit opening tool to pry up the plastic cover.
    • Use tweezers to remove the wire from the slots.
  10. Samsung HMX-W300 USB Port Replacement: 10 단계, 이미지 1/2 Samsung HMX-W300 USB Port Replacement: 10 단계, 이미지 2/2
    • Remove both screws from the USB port using a Phillips #00 screwdriver.
  11. Samsung HMX-W300 USB Port Replacement: 11 단계, 이미지 1/2 Samsung HMX-W300 USB Port Replacement: 11 단계, 이미지 2/2
    • Push the USB port inside the case to remove it from the device.
결론
Robert
회원 가입일: 01/21/15
966 평판
안내서 8개 작성하였습니다
USF Tampa, Team 9-2, Blackwell Winter 2015 USF Tampa, Team 9-2, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G2
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 418
