주요 콘텐츠로 건너뛰기
Samsung Impression Circuit Board Replacement
필요한 것
  1. Samsung Impression Circuit Board Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
  2. Samsung Impression Circuit Board Replacement: 2 단계, 이미지 2개 중 1개 Samsung Impression Circuit Board Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
  3. Samsung Impression Circuit Board Replacement, Back Cover: 3 단계, 이미지 1개 중 1개
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
  4. Samsung Impression Circuit Board Replacement: 4 단계, 이미지 1개 중 1개
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression Circuit Board Replacement, Back Speaker: 5 단계, 이미지 1개 중 1개
    • Carefully pry the back speaker upwards with a spudger.
    • The speaker is still connected to the circuit board by a wire and small piece of clear plastic.
    • Disconnect the speaker by lifting the clear plastic piece attached to the wire.
  6. Samsung Impression Circuit Board Replacement, Circuit Board: 6 단계, 이미지 1개 중 1개
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
  7. Samsung Impression Circuit Board Replacement: 7 단계, 이미지 2개 중 1개 Samsung Impression Circuit Board Replacement: 7 단계, 이미지 2개 중 2개
    • Gently tug the black and blue ribbon upwards to release the circuit board.
결론
To reassemble the device, carefully follow these instructions in reverse order. With a new circuit board installed, your phone should be functional again! For more guides on Samsung Impression maintenance, visit www.ifixit.com.
작성자
11다른 기여자 명과 함께
Ross McKelvie
회원 가입일: 04/18/11
196 평판
안내서 4개를 작성함
Cal Poly, Team 8-10, Regan Spring 2011 Cal Poly, Team 8-10, Regan Spring 2011 회원
CPSU-REGAN-S11S8G10
4 회원들
안내서 23개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 15
전체 시간: 3,974
